Old 03-04-2005, 12:42 AM   #1
firemanchuck
FightingFire Saving Lives
Tranny question?
I have a 350 with a 3-speed on the tree. I really want to swap it out for a turbo 350 with a np205. What should I expect to pay for this set-up? any advice or help would be awesome.
Thanks, Chuck
firemanchuck is offline   Reply With Quote
Old 03-04-2005, 07:19 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
depends on what the going rate is in your area, here a 350 w/ 205 attached can be had for under $500, and that's ready to bolt in. Less if they need rebuilding. You'll need to swap out the steering columns, also the automatics have a couple switches in the steering column near the firewall that will/should be dealt with (neutral safety and back-up lights). Need to make sure you get the brackets for the linkeage. As I understand the cross member is the same between the autos and 4 spds not sure about the 3 spds.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-04-2005, 10:59 AM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah, JIMs70GMC-has good advice. Make sure you hook up the switches in the steering column though. As for if it will line up with the 3 spd or not I have no idea.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
