Old 03-04-2005, 02:33 AM   #1
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
left turn signal makes the horn honk!?
Hey all. when I try & signal for a left turn, the horn honks... Its kinda funny for a while until the guy in front of you is lookin at you with a "whats your problem?!" look in the rearview mirror. Do I need a new turn signal or something else? Thanks for your help...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 03-04-2005, 05:34 AM   #2
cdowns
cdowns's Avatar
it's probablly a bad wire in the steering column,you'll have to remove the steering wheel and check the turn signal switch something there is making contact with the steering shaft causing the horn to blow
Old 03-04-2005, 08:17 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
does your turn signal lever wiggle at all? I've seen manyu columns like this where the screw that holds the turn signal lever becomes loose and grounds out the horn.
If it does wiggle, just need to pull the steering wheel, (a puller is required...can be had pretty cheap, and a tool worth having) and tighten the small philips screw retaining the lever. You'll want to inspect the plastic that the screw goes into, becouse it is very common for that plastic to split making it imposable to tighten.
Old 03-04-2005, 07:32 PM   #4
passthebuck
Talking
the handle is totally wiggly & has been for some time but I've been too lazy to bother to pull the wheel. this is a good tip Longhorn Man. thanx. I'll check it out...
passthebuck
#5642
Old 03-04-2005, 07:47 PM   #5
Longhorn Man
If you were to go out and look in the hole in the colimn where your turn signal lever comes out, and wiggle the lever...I'd bet you'll see a spark or two as the horn sounds off....more obviouse at night of course.
Old 03-04-2005, 08:05 PM   #6
avejoe
Custer had a plan too.
avejoe's Avatar
If you are too lazy to fix the problem, just use your horn button to make left hand turns.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 03-04-2005, 09:01 PM   #7
smitty62
smitty62's Avatar
You could drive around a circle (counterclockwise) until the horn burned out!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 03-07-2005, 03:23 PM   #8
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Originally Posted by Longhorn Man
...tighten the small philips screw retaining the lever. You'll want to inspect the plastic that the screw goes into, becouse it is very common for that plastic to split making it imposable to tighten.
Ok, since this one seems to have played out, and passthebuck may learn he has my same problem, let me ask a related question.
Indeed the plastic thingy was broken under the screw, so we replaced just that top yoke with a kit from the Help! section.
Problem is, the PO used a sheet metal screw to hold the signal lever in the hole, and it is stripped. I suspect it was originally machine threads, but now I can't get any screw/bolt to grab in that hole.
Recommendations? What is that screw supposed to be, and what does it thread into? What will need to be replaced?
Thanks...SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 03-07-2005, 04:58 PM   #9
screamin_c102
screamin_c102's Avatar
JB-Weld or 2-part Epoxy the screw in place. Use just a dab of grease on the threads, this will enable you to remove the screw at a later date. You actually can tap threads into JB weld for larger repairs.
screamin_c102 is offline   Reply With Quote
Old 11-21-2011, 09:25 PM   #10
schurg
Re: left turn signal makes the horn honk!?
I hate bringin up old topics..but this is happening to my truck as well. the screw that holds the signal lever in place is hitting the horn disk. the previous owner must've had issues and put a hex screw in to hold the lever in place. I have filed it down to nearly nothing and it still hits the disk (this must have been going on for a while as the old disk was destroyed when I pulled it out and there was a pile of shaving in the bottom of the column :P ). does anyone have a pic of the screw that is supposed to be in there? thread wise, head wise, etc. thanks
schurg is offline   Reply With Quote
Old 11-21-2011, 09:51 PM   #11
FLcustom10
Here's the head. I could have shown you the threads about an hour ago, but I'm not taking the steering wheel back off now!
FLcustom10 is offline   Reply With Quote
Old 11-21-2011, 09:57 PM   #12
schurg
thanks! that helps...what's weird is it looks like where my screw goes is further to the right then yours...the head is halfway under the disk. I gotta say, thats a damn clean lookin dash you got there, very nice!
Old 11-21-2011, 10:13 PM   #13
FLcustom10
Thanks! Here's another view from an angle with the old cracked switch to see if that gives you any hints.
Old 11-21-2011, 11:14 PM   #14
schurg
thanks again...I swear I must have the wrong column, signal switch or turn signal lever...lol...things just dont look like that in my truck.
Old 11-22-2011, 12:29 AM   #15
Rooster's 67
Rooster's 67's Avatar
9 out of 10 failures with this symptom will be a failed turn signal switch. if the screw is loose tightening will generally be a temp fix, replacement is due.
love draggin up six year old threads...lol
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 11-22-2011, 12:48 AM   #16
schurg
my switch assembly is new, unfortunately I gotta work with what I have. if I go to napa and get a switch assembly for a '68 c10, that's what I get, if the column is out of something else, which is what I'm starting to think, then things might not work out so well..lol. I bought some parts from lmc recently and only 1 part worked (horn button parts, turn signal cam, shift indicator lens). I can only take a trip to the hardware store and try to find an ultra low profile screw and slam er in there
and I feel some of these threads are timeless, no?
Old 11-22-2011, 01:16 AM   #17
domeier
domeier's Avatar
If you turn right, does it backfire?
domeier is offline   Reply With Quote
Old 11-22-2011, 03:44 AM   #18
BlazinC5
BlazinC5's Avatar
hee hee hee, This thread reminds me of a pickup my dad handed down to my older brother. It was a 1982 chev with a 6.2 diesel and an automatic. One day the high beams quit working and eventualy outa frustration my brother hit the steering wheel with his fist. bumping the horn. The high beams came on. Ah HAH. honk the horn and they came on.. Bad part was you didn't want to touch the gear selector on the column when ya honk the horn. It would shock the crap outa you. I think dad did take that thing apart and found the bad wires but not before my brother tricked a few people including his at the time girlfriend into touching the selector.
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
Old 11-22-2011, 11:27 AM   #19
passthebuck
Wow - I posted this one a long time ago!
I ended up replacing the signal switch because the screw wouldn't hold...
passthebuck
#5642
Old 11-22-2011, 11:36 AM   #20
mr48chev
mr48chev's Avatar
At least Schurg knew it was an ancient topic but he had had the same problem. That is something that happens to almost all of us who have one of these trucks and in fact I need to change the turn switch out on mine now.
Old 11-22-2011, 08:49 PM   #21
CC69Rat
CC69Rat's Avatar
I'd just drive around with my blinker on and the horn honkin and act like I didn't notice. .. and just watch people.
No, I don't get out much ..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-13-2013, 12:29 PM   #22
chevy72blu
chevy72blu's Avatar
Bumping this now ancient thread, again!
Got my truck back on the road for the first time in years yesterday and you can imagine my (and the adjacent drivers) surprise when my left resulted in a HOOOONK. I used hand signals for the rest of the test drive
I havent gotten my wheel off yet, but I suspect its the signal lever being loose on the switch body. It had been wobbly for years when I was driving it. Perhaps I'll just go ahead and replace the whole thing to save me a headache later.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-13-2013, 05:28 PM   #23
NCBowtie
I had this problem a month or two ago. Unfortunately, my horn eventually started honking at random so I couldn't just ignore it. Kind of makes you want to crawl down in your seat when it happens.
My brake lights also stopped working when I had the left signal on before any of the honking started too.
NCBowtie is offline   Reply With Quote
