Old 03-04-2005, 01:30 PM   #1
booth
Active Member
booth's Avatar
WTB A set of Duels, MN?
I am looking for a set of duels that I can bolt to my Dana 60. Possibly in MN
Thanks,
Paul
'67 Chevy LWB (Running)
'67 Chevy LWB (Not Running)
'70 Chevy LWB (In Pieces)
'72 Chevy LWB (In Pieces)
booth is offline   Reply With Quote
Old 03-04-2005, 02:32 PM   #2
sakohntr
sakohntr's Avatar
st paul
You can buy them brand new in St. Paul from pioneer rim and wheel for about $42.00 a piece. Even if you got some used ones for 20, you still gotta blast em, paint em and hope there straight or pay to get rid of the skins on em. You can get exactly which size you want too. good luck
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 03-04-2005, 03:19 PM   #3
booth
Active Member
booth's Avatar
Sakohntr,
Do you know what wheel size you used. I was talking to a sales guy there and his book didn't go that far back '67. Then he starts talking about stud size and pilot size, which I wasn't sure about.
Paul
Old 03-04-2005, 04:24 PM   #4
sakohntr
sakohntr's Avatar
info
Talk to junkyardjohn on wheel studs. He knows more than I. I dont know what year you are putting them on but i do know they changed to a larger diameter in early 70's. You might want to upgrade to the larger if you dont have them already. I dont believe the pilot hole dimension ever changed on GM.
Old 03-04-2005, 05:23 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
The wheels I got from them were dated GM 1976 to 2000. Pre 76 wheels where still split rim 2 pc style. They will have a 4-5/8 diameter hub center and they will be set up for 1971 and later 9/16" wheel studs not the 1/2" earlier studs. If you run a wider tire on these rims, you will also need to add a spacer between the 2 rims. I think I am running 235-85-16 tires on my motorhome and they rubbed. It also meant I had to install longer studs too.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
