Old 03-04-2005, 11:44 PM   #1
72dually
72dually's Avatar
Power windows?
I know there was a thread, but I didnt read it, now I'm interested, Im just curious if they make a kit for our trucks, and if so, generally how much $$, and who makes it????
72dually is offline   Reply With Quote
Old 03-05-2005, 12:05 AM   #2
Randy70C-10
Randy70C-10's Avatar
Power Specialties makes power window kits for just about everything but you can probably adapt a power window assembly from a later model junk yard truck alot cheaper. A friend of mine used the power assembly from a late model Caddy in his 46 Chevy pickup.
Randy70C-10 is offline   Reply With Quote
Old 03-05-2005, 12:16 AM   #3
Bob Moore
Check out the ElectricLife as sold by A1Electric. Bolt in operation using existing hole in your doors. $239.95 with free shipping.
www.a1electric.com
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-05-2005, 10:18 PM   #4
72dually
72dually's Avatar
Thanks Bob, I like it
Old 03-05-2005, 11:17 PM   #5
72402
I put that ElectricLife setup in a 67 pickup a while back. Easy install and worked great. Took longer to put the conduits in the jambs and run the wires than it did to mount the regulators.
72402 is offline   Reply With Quote
Old 03-05-2005, 11:51 PM   #6
hilljob26
hilljob26's Avatar
electriclife windows are great,and will work w/ one piece windows if you are going to that...
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 03-06-2005, 04:09 AM   #7
John Fabris
TOTY 2006
John Fabris's Avatar
72402, What did you do for your electrical thru the jams? I am just starting to look at what I can do, but wondered if you had picture of what you did?
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 03-06-2005, 12:03 PM   #8
rustyg
rustyg's Avatar
Has anyone installed their power door locks
71 k10 swb
72 k5
72 Burb 4x4
72 GMC Burb 4x4
rustyg is offline   Reply With Quote
Old 03-06-2005, 09:17 PM   #9
72402
Door jamb conduits
John, I don't have any pictures, but I used a set of conduits made by Specialty Power Window Co. They are just stainless steel springs with a rubber grommet that holds one end stationary, the other end slides in a nylon bushing. Available from several street rod parts suppliers. I buy mine from Parr Automotive in OK City; they're close-overnight shipping. Not much room for error in the jambs of these trucks. They have to go through close to the weatherstrip. There's a diagonal brace in the front of the door. You'll have to cut a hole through it, then drill through the door. I actually cut another hole in the door , just below the window regulator, for better access. There are several other styles of conduits, plastic, braided stainless, etc., but I've used these in several applications and they work really well.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
Old 03-06-2005, 11:17 PM   #10
TxGary
TxGary's Avatar
I have just put A1 Electric power windows & power locks with keyless entry in my 69 C-30. Real nice fit with easy to install. Used a rubber grommet from GM #15326220 they were $7.63 ea. Will attach two pictures of the grommet.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 03-08-2005, 03:24 PM   #11
Edmond
Edmond's Avatar
That's what I want. Looks perfect!!
Thanks for the info TxGary!!
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 03-08-2005, 04:34 PM   #12
John Fabris
TOTY 2006
Perfect Pictures and a part number! What else could you ask for!!
Thanks TxGary....
John Fabris
67 C10 SWB
Old 03-08-2005, 05:13 PM   #13
tonyj
hey rusty.... just curious why does a person from PA have a road sign from so calif in there corner......lol interesting name though...
tonyj is offline   Reply With Quote
Old 03-08-2005, 05:22 PM   #14
bagged91
Out draggin'
bagged91's Avatar
tonyj, he just moved to the east coast about a month ago...
TxGary, that is sweet...
Has anyone used the A-1 kit with the switches that Auto-lok & others sell that allow you to keep your stock window handle and use it as the switch?
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 03-08-2005, 05:45 PM   #15
longnlow72
longnlow72's Avatar
those switches are cool but there $100 per switch
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 03-08-2005, 06:43 PM   #16
pat
pat's Avatar
Can I buy just the standard kit from a1electric and then buy wire and switches on my own from an auto parts store?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 03-08-2005, 10:43 PM   #17
71RestoRod
71RestoRod's Avatar
I just ordered the A1 kit and Auto-loc crank switches yesterday. Saved a little on the switches... still not cheap. Got them from a place called the Car Shop for $86 each.
Looking at pictures of everything online, I really don't think the crank switches will work with the A1 kit. The folks at A1 didn't know. I wanted to find out for sure... so I let you know after the parts arrive.
71RestoRod is offline   Reply With Quote
Old 03-09-2005, 12:41 AM   #18
72402
RestoRod, I think you're right. Since these regulators mount in the original location, I don't think there'll be room for the switch where the original shaft came through the panel.
Old 03-09-2005, 01:59 AM   #19
barn9
Half a bubble off!
barn9's Avatar
Quick thought, anyone that is doing this conversion, it would be great if you would keep the camera handy and do a "how to" for the FAQ section.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 03-09-2005, 04:04 AM   #20
pat
pat's Avatar
http://www.a1electric.com/chevypickup1.htm
heres their 'how to'
Old 03-09-2005, 11:23 AM   #21
Maximum Overdrive
December 21, 2012
One of the truck mags, don't remember the name, just installed electric windows in one of the 67-72 trucks from electric life. It was a current issue, well current up here anyway.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 03-09-2005, 12:30 PM   #22
Edmond
Edmond's Avatar
Originally Posted by pat
I wish they showed a better picture of the wiring...
Cya,
Edmond
The Netherlands
Old 03-09-2005, 02:10 PM   #23
Bob Moore
Re: Window Crank Switches
Another source for the window crank switches is www.hotronicsproducts.com. I believe they are the originators of this product. I also have concerns if they would fit the 67-71 door panels and also in particular the 72 style.
The electric life windows are literally a bolt in kit(forgetting about the wires and switches). My understanding is that they metric fasteners(included) to bolt through the existing holes in the door. I think they are quite simple to install.
Another source for switches, etc. is Streetrod Shop of Camus, WA. They were at the local swap meet with products on hand. Reach them at the following: www.streetrodshop.net
I am very interested in learning if the crank style switches fit the doors with powerwindows or not.
Keep us informed - Thanks - Bob
vac, 454, T400
more to follow
Old 03-09-2005, 04:58 PM   #24
shifty
Questionable
shifty's Avatar
Here, this article should help too:
http://www.classictrucksweb.com/tech...dsc/index.html
"Install One-Piece Power Windows in Classic Chevy Truck"
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-10-2005, 02:30 AM   #25
Edmond
Edmond's Avatar
Thanks for that link Shifty!!
Now this is a good pic...
Cya,
Edmond
The Netherlands
