Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-05-2005, 03:31 AM   #1
qksilver
65 burb
I have a 65 burb that needs rockers, floor and not sure what they are called but the inside panels where the door hinges mount. I want to find a complete section from windshield posts at the roof to behind rear door posts. Rust free, no laughing, section from a pick up cab or burb. I don't want to piece it together.
Either a cab section or if any body knows/has a 65 burb tub they want to sell.
i have a option load 65 that the back end is perfect. It was parked half under a car port with the front end out with a bad windshield gasket
qksilver is offline   Reply With Quote
Old 03-05-2005, 03:43 AM   #2
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
THere's a 64-66 GMC cab on Ebay right now going for 1 cent.
64-66 gmc cab
I hope this helps.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 03-05-2005, 10:58 AM   #3
64fleetside
I have a C60 cab from a barn truck, no rust in floors/rockers at all, has one small rust spot on pass cab corner where some rags were left. I have never seen unrusted rockers like this cab has. I am asking $200, in central Arkansas. Brian
64fleetside is offline   Reply With Quote
Old 03-05-2005, 12:57 PM   #4
qksilver
Thanks, that cab rust is worse than mine! Is there any difference from a C-60 floor, toe boards and fire wall to a C-10?
Old 03-05-2005, 02:22 PM   #5
64fleetside
There are slight differences, the front cab mounting hole is in a diff spot, there is two master cyl holes as truck has hyd clutch. Trans hump is similar to 4 speed truck but pan itself is flatter & has hole for ebrake. Brian
