03-05-2005, 04:04 AM | #1 |
Got Horsepower?
alternator died
need a new alternator should i go with a stock or internal regulated type? how much more would it cost for the internal regulated alternator?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
03-05-2005, 05:18 AM | #2 |
I would go with an internally regulated unit. I think most people would say the same. A typical internally regulated 63-Amp Alt usually runs around 50 bucks at most auto parts stores and the plug is usually around 5 bucks. It is really easy to do and I believe there is a write-up in the FAQ section.
03-05-2005, 05:26 AM | #3 |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
03-05-2005, 11:52 AM | #4 |
Half a bubble off!
Internally regulated by all means.
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
03-05-2005, 11:58 AM | #5 |
Got Horsepower?
is it the same size as the one already on there? what about 1 wire alternators?
03-05-2005, 02:37 PM | #6 |
Msgt USAF Ret
bad alternator
How did you determine that the alternator is bad? No charging, makes noise
what? They are pretty easy to fix if it's a bad bearing or brushes or a diode. Here's a website that explains a lot about one wire alternators and also there are some threads posted just recently about leaving the idiot lite wire hooked up to excite the charging circuit in the alternator. I think it was started by Putter. The search feature isn't working yet or you could use that. http://www.madelectrical.com/electrical-tech.shtml Vettevet- old and knows alternators
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-05-2005, 03:00 PM | #7 |
Not Mine But A beauty
i got mine in the junkyard an internally regulated 94 amp from a 87 silverado only 86-86 have it howver i had to change the pulley it was serpentine i changed over to v-Belt works great btw
68 Chevy Shortbed 454/400 2000 Chevrolet Camaro SS 6spd 2011 Silverado 5.3 6spd auto |
