03-05-2005, 02:35 PM | #1 |
What size wheels should I use?
I have a 79 4x4 and I'm going to get some aluminum rims for it. I currently have 32-11.50-15 tires on the truck when they wear out I'll probably go with 33-12.50-15's. My question is, should I get 15x10 or 15x8 wheels? Which would look better?
03-05-2005, 07:54 PM | #2 |
Uncle H. is this cartoon
In magazines like 4wheel & Offroad you see wheel and tire packages all the time listing 33x12.5"-15 tires always mounted on 15x10 rims. BFG says they like to see between 9-11" rim width.
Some people on this forum say they use 15x8's. The narrower rims will probably keep a tire on at lower pressures. Mostly I here people use 15x8's for clearance on stock height vehicles. For looks, I think the 15x10 is nicer... Anyone else? |
03-06-2005, 02:38 AM | #3 |
Big no on the 10" rim with 12.50s. They leave the rim edges more exposed to damage from rocks and the bead more vulnerable to popping off when aired down compared to 8" rims. Or 8.5". Contrary to popular belief, the 8" rims will not cause radial 12.50s to "crown" and wear more in the middle than at the edges. I run BFG 33-12.50-15s @50psi on the road with no adverse wear characteristics. I used to think 50psi was way too much pressure, but I've since learned that radial carcasses conform to the road surface so well that they won't crown so easily as bias tires will. Especially when dealing with large, off-road tires. Lower pressures allow 12.50 BFGs in at-speed turns to roll under at the outer edges which increases wear at the outer edges compared to the rest of the tire. More of a front tire concern, but not entirely.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
