Old 03-05-2005, 03:58 PM   #1
67chevy2wd
67chevy2wd's Avatar
Air Ride
I am planning on installing air bags this summer and was wondering if they come in different heights. Do you need different bags for a 4/6 drop than you do for a 2/4 drop?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 03-05-2005, 06:42 PM   #2
smbrouss70
smbrouss70's Avatar
Air bags are adjustable to any height you want (within limits) that's what makes them so cool. So to answer your question "No, you don't need different height air bags."
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-05-2005, 07:02 PM   #3
67chevy2wd
67chevy2wd's Avatar
But I will have a stiffer ride at 2/4 than 4/6 or not. I was also looking at getting tubular A arm's, would that be the way to go?
'71 GMC 3/4 ton 4x4
Old 03-05-2005, 07:15 PM   #4
XXL
Señor Member
XXL's Avatar
I recommend you spend some time reading the dozen or so threads in this forum that discuss these very topics. They'll likely answer most questions you have.
XXL is offline   Reply With Quote
Old 03-05-2005, 07:30 PM   #5
67chevy2wd
67chevy2wd's Avatar
I will do that thanks. Does anyone know if you can order a suicide doors catallog? I tried finding the link on their website but had no luck.
'71 GMC 3/4 ton 4x4
Old 03-06-2005, 04:12 AM   #6
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Yes, airbags come in many different heights (sizes) as well as different styles. Each airbag also has a specific load capacity rating. Although the ride height of an airbag can be changed by varying the air pressure, each airbag has a recommended installed height. The final installed height may be fine-tuned based upon your ride preferences. So, the same bag could be used for a 4/6 drop as well as a 2/4 drop. To some degree, you could change the mounting position based on your desired drop to maintain the recommended install height. Hope this helps. (Many of the threads in this forum can give you much more information and the details.)
BTW, I'm not aware of any (hardcopy) catalog that Suicide Doors distributes. Aside from their online listings, you could email or call Suicide Doors.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
