06-02-2002, 08:05 PM | #1 |
irratic idle problem
I have a stock 350 in truck and has developed an irratic idle after driving for a few minutes, particularly noticable when running air conditioner. Gave truck a tune up(cap, rotor--hei, plugs, wires, fuel filter) wonder if carb is problem. I'm running 8btdc on timing with an idle in gear of 700 but even with the strain the ac puts on the motor I would'nt think I should have to re-tune the engine for air use. Carb is edelbrock 1406/elec choke. Basically feels like the truck is flooding when using the air. Help??
68 chevelle(garage queen) 72 cheyenne super(driver) Owasso, Oklahoma |
06-02-2002, 08:51 PM | #2 |
its all about the +6 inches
Is this a new problem?
Does it only do this when the engine has been running a while? I ask becouse these AFB carbs are very sensitive to vapor lock. Also sounds like your floats may be too highallowing raw fuel to be dumped into the carb. |
06-02-2002, 09:38 PM | #3 |
GM uses a fast idle solenoid to bump up the idle when the AC is engage on the Q-jet. Lowers rpm by about 200 in my truck, but it idles fine at 600. The compressor is a significant load on the motor. I put a 50% underdrive crank pulley on my Camaro and had to lower the idle 400 rpm!
06-04-2002, 08:50 PM | #4 |
Where would the fast idle solenoid be if my truck were to have one. I have been running this carb for about a year and until recently I can't recall it having this problem before. At first start it idles fine but after a warming up it starts to resemble a flooding situation. You thoughts are appreciated---
06-04-2002, 09:02 PM | #5 |
CCRider
How much cam are you running? If running a larger than stock cam the A/C may be dropping the vacuum enough to open the power circuit on the carb causeing a flooding condition. If this is the case you will need different springs on the metering rods. Just a thought.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
06-04-2002, 09:18 PM | #6 |
motor is bone stock 350, factory air setup, dual exhaust--starting to wonder if carb needs rebuild kit, maybe floats are filling with fuel and it takes a while to do so. might be whats happening
06-04-2002, 10:33 PM | #7 |
CCRider
OK that was my first guess but here are a couple more. First check with a vacuum gauge and make sure the motor will hold 17 - 18 inches of vacuum in gear with the A/C on. If not the power circuit in the carb could still be the problem. If it will not hold that much vacuum, first use some carb cleaner and check for vacuum leaks. Spary the carb cleaner anywhere you suspect a leak and if the idle changes you found it. If that doesn't turn out to be the problem, try using the vacuum gauge to adjust the timing for more vacuum, I have seen many small blocks that the timing marks were not correct. In fact I would run as much timing as the motor will tolarate anyway because you will get better gas milage. Advance the timing till the motor "pings" under full throttle, then retard the timing till it just stops. This is usally the best setting for a sbc if the starter will tolarate it. Many times you can run 10 - 12 degrees btdc with premeium fuel. Last I have seen old vehicles have rust in the fuel lines that will go right thru a fuel filter. If this is the problem you will have stuff in the carb that looks like mud. The only solution for this is to replace the rusted component. I have run as many as three filters and still it will come thru. Good Luck!
06-04-2002, 11:25 PM | #8 |
You might check fuel pressure too....the 1406 cant handle anymore than five lbs of pressure. If all else fails a carb spacer might help.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
