Keepin an eye out
3-5 spring drop...
Has anyone done this drop? Right now I have cut springs up front and heated in the back. It looks like a saggin 2-4 drop as these are original springs.
Im thinkin 3-5 will be close but I dont want alignment issues. I already have shock relocators and a adjustable trac bar and will probably get new shocks w/ the springs.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Keepin an eye out
Come on anyone using 3-5 spring combo?
67-72 Addict!
I think Tim Christian did this on his sons truck and maybe Gene also. Their trucks look great!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Got Big Block?
Mine is supposedly has 3" springs in the front and 4" springs in the rear. I don't know for sure because I bought the springs slightly used and didn't see any numbers on the springs. Personally I think it sits about 1" too high in the rear. As far as alignment, It seems to ride and drive just as good as it did before (which is pretty darn good.)
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 03-07-2005 at 02:10 PM. |
Nice Rallys Brit!!!
Alex 1971 Lil' Red 350 SBC 700R4 |
#6 | |
1972 C10 SWB 350 / T400 1972 SWB GMC 350/T350 1972 Cheyenne 20 super "long horn". 402BB / T400 1972 Suburban C10 Deluxe 350 / T350 and a few more.. http://www.myspace.com/afew72s |
Got Big Block?
thanks Alex. Now if only they were real....
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 03-07-2005 at 02:17 PM. |
woah....is it just me or is the rear bumper tweaked?
looks tweaked to me....even with my head turned sideways..i like the rolled pan look myself
Tweaked definatly tweaked........... Damn were a picky lot.
I got a bench seat baby, you don't have to sit over there. |
3/5, with 1 1/2" body drop tossed in.... http://community.webshots.com/user/hotrodhorn
http://community.webshots.com/user/hotrodhorn |
#12 | |
Keepin an eye out
#13 |
Here is mine. It has a 3.5/5. I haven't had any alignment issues that I can remember, but then again, I have had so many problems with everything else that I could have just forgotten
Build Thread |
#14 |
Green club
Low 68, have always liked your truck, that's one sweet ride
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
#15 |
Keepin an eye out
Very nice Low68. I ordered my 3-5 springs w/ new gas shocks from Athey's Classic Truck Parts and took advantage of the 10% off offer they have going this month. Fresh suspention makes me happy
#16 |
Thanks, I appreciate it.
Low68
Build Thread |
#17 |
PURS What size rims and tires are you riding on? Are those rally's
#18 |
Got Big Block?
they are 17x8 wheel vintique rally's with a touch of Photoshop
"Experience is what you get when you didn't get what you wanted." |
#19 |
Could I ask the cost per wheel and do they come in 17x9 or 10's? They look really good on your truck
#20 |
Got Big Block?
They don't make the steel rally's in anything wider than 17x8
#21 |
How much are the Steel versoins
#22 |
in 17x8
#23 |
I have a 2-1/2" drop spindle in the front and a 4" lowering spring in the rear. on a LWB. It looks good, w/15x8 245-60-15 and 15x10 295-50-15. I want to go bigger with the rim size and also use a blazer style tank. I wouldn't recommend going with a 4" spring in the rear if you plan to use a rear mount tank. I've got to pull my 4" and try a 3" due to the rear end may set lower than the front.
#24 |
-Praise the Lowered-
here's a long bed with 3/5 spring drop....
bought them from CPP
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) Last edited by race-n-jason; 03-10-2005 at 06:53 PM. |
#25 |
Questionable
Hey, Jason, your truck looks pretty damned low compared to the other guys with the same drop. How is your ride with only using springs to drop it? About the same as stock, too stiff, or a little squishy?
What size wheels you got?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
