Old 03-06-2005, 01:19 AM   #1
Cruz Lo
Cruz Lo's Avatar
Have to Slam Door After Adding Weatherstrip
Has anyone ever had this problem? I installed the door weatherstrip on the passenger's side and now I have to slam the door for it to close all the way. Not just a normal slam. I have to aggresively throw the door for it to shut all the way.
1968 C10 SWB, Fleetside, 350/350, FBSS Airbag Suspension
Cruz Lo is offline   Reply With Quote
Old 03-06-2005, 01:23 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It will ease up after the new rubber takes it's shape.
Give it a few weeks.
Old 03-06-2005, 01:43 AM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
That's normal. Just as Tx Firefighter said. I put the S-10 weatherstripping on mine and I didn't think I could even shut the door but once shut and left sitting a couple of days it's fine.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 03-06-2005, 02:01 AM   #4
Cruz Lo
Cruz Lo's Avatar
Cool. Thanks for the help. I thought I was going to have to reallign something.
Old 03-06-2005, 02:56 AM   #5
4x4Poet
BTW, what brand weatherstrip?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-06-2005, 07:55 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
You may have to re-adjust if it doesn't fix itself. I had to on mine after installing new repro weatherstrips. I waited about 2 weeks and it wasn't getting any better.
All I did was to loosen the hinge to cab bolts on both hinges just a bit, not too much, then shut the door. Open back up and tighten the bolts. That was enough in my case to position the door out a bit.
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 03-06-2005, 08:45 AM   #7
Randy70C-10
Randy70C-10's Avatar
I never thought of doing that, I haven't installed mine yet but I was worried from reading on this subject before. Good info!
Randy70C-10 is offline   Reply With Quote
Old 03-06-2005, 10:16 AM   #8
oleblue72
No, U Da Man!
oleblue72's Avatar
The weatherstripping I used had small perforated holes in it, I assumed it was to help it collaspe when the door was closed.
(sold ole blue 1972)
1997 Dodge 1500 5.9L
1996 Saturn SL2 1.9L
2002 Mitsubishi Montero 3.0L
2005 Ford Escape 3.0L
1967 Olds Vista Cruiser 330-320HP
oleblue72 is offline   Reply With Quote
Old 03-06-2005, 12:58 PM   #9
Cruz Lo
Cruz Lo's Avatar
I bought the weatherstrip door kit from LMC Trucks. I'll see if it improves after a couple of weeks.
Old 03-06-2005, 07:40 PM   #10
greasemonkey
greasemonkey's Avatar
oleblue72, where did you buy your weatherstripping from? That's the kind I am looking for.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 03-06-2005, 08:59 PM   #11
rage'nrat638
rage'nrat638's Avatar
yea try locking it with out pushing in on the door...
you can always adjust the striker ....to help correct the problem...
the rage....
rage'nrat638 is offline   Reply With Quote
Old 03-06-2005, 09:36 PM   #12
4x4Poet
To the best of my knowledge and meager personal weatherstrip experience, Softseal is the best weatherstrip out there. I've read this in several classic car auto mags, too. But I'm no restoration expert, so take this with a grain of salt.
I can provide a 60-72 vender that only sells Softseal weatherstrip for our trucks because he knows from personal experience and customer satisfaction that Softseal makes quality pieces.
Old 03-06-2005, 10:21 PM   #13
STP67-72
STP67-72's Avatar
weatherstrip
I have used both and sell both. Soft seal is twice the money. I use them on my nicer trucks.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 03-07-2005, 01:32 PM   #14
Cruz Lo
Cruz Lo's Avatar
Well after having the door shut for the rest of Saturday and all of Sunday, the door is back to normal. It closed perfectly fine this morning. Now on to the driver's side.
Old 03-07-2005, 01:45 PM   #15
70c10
67-72 Addict!
70c10's Avatar
Bill Athey told me to try a neat trick. Poke several small holes around the gasket where you won't see them to relieve some pressure. I used a test light probe.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
