03-06-2005, 01:49 PM | #1 |
Fuel filter and lines
Been having problems with smelling gasoline fumes. I want to replace the fuel filter and the lines on either side of it. The lines are showing some cracking, so I hope that is the cause of the smell.
Couple questions: (1) Any fuel filer recommendations? (2) Do I need to do anything special to remove and replace the lines? (Will there be much gasoline in the lines that I need to worry about, or should it be ok to just remove and replace?) Sorry for the basic questions, but I am trying to learn to take care of this truck and have had virtually no auto repair experience. Heres a pic of the location.
Hook'em |
03-06-2005, 02:20 PM | #2 |
Wear some glasses and keep your mouth closed and move quick. I did this a few weeks ago and I ended up burning most of the clothes I was wearing afterwords.
-Cory 1967 2 Wheel Chevy |
03-06-2005, 02:39 PM | #3 |
F.A.S.T. president
If your new to turning a wrench
1. do it when the engine is cold 2. use only fuel rated hose 3. replace clamps 4. pay attention direction of filter (inlet/outlet) 5. Route new hose away from excesive heat source and belts, pullys or anything that may cut or rub a hole in the hose. 6. dont be too far way from a fire extinguisher (you just never know when you have a little fuel spill) On another note, I would move that ground cable to the block insted of the intake. Not that it will cause any damage there, its just more efficiant for the cranking system.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
03-06-2005, 04:23 PM | #4 |
There is also a short rubber hose @ 8" long under the cab that connects the gas tank to the main metal fuel line, you shd. inspect and or replace that also (unless already done) careful though can get messy & wear safety glasses. ^ and what JAMIS mentioned.
03-06-2005, 05:35 PM | #5 |
For safety's sake, youy should replace the rubber hose set up from the fuel pump and replace it with the steel line that came from the factory. The engine compartment is too hot and full of electricity to trust a simple hose clamp fitting on a fuel line. A fire can easily start when one of the splices leakes and drips on a spark plug wire. A replacement steel line is less than $20. If you have a carburetor that does not work with the factory set up, then at least run the steel from the fuel pump up close to your carburetor and finish off the rest with a flexible, fuel rated hose. Just my $0.02. Thanks.
1971 Cheyenne 1/2 ton 2WD Long Fleet (sold) Steve |
