Old 03-06-2005, 03:32 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
305 wont start
305 wont start
this motor came out of my 72 4 years ago runing in great condition. I have had to pull a 250 out of my 81 1/2 ton and put this 305 in there. the dizzy had been pulled prior to going innto the 81, now everything is in place and I'm pretty sure the dizzy is correct and the plug wires are correct on the dizzy, if I throttle the carb, by the way the carb is a edelbrock 1405 manual choke, (not hooked up)
I cant see the gas ,but I can see where you can see the mist comming out of the top of the carb. it wont start. when i crank the motor over it cranks good and then maybe after 4 to 8 seconds of cranking it will back fire,(sometimes flames out the carb). I have rechecked the timing, I'm pretty sure it is correct from what the chilton's says. new spark plugs. could it be that I am missing something, I have to get this running today and I am getting no-where...
Please any input I would appreciate and defenitly run outside to try
Its Gonna be a Great Day, I woke up this Morning.
Edit/Delete Message
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 03-06-2005, 03:57 PM   #2
RainFade
RainFade's Avatar
You don't have your distributor 180 degrees out by chance ?
I'd pull the #1 plug and make sure it is TDC on compression when the rotor points to #1.
It has been sitting 4 years, I assume it has been in doors and was prep'd for storage ?
Point distributor I assume ?
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 03-06-2005, 04:14 PM   #3
tphsmith
tphsmith's Avatar
the motor had been in the garage all the time, I have pulled the #1 plug and made sure the piston was at the top of the stroke, and each time (3) the rotor was always pointing at # 1. this is an HEI distributor. I pulled #1 spark plug and checked for spark on it and yes there is spark, new plugs gapped at .045. there is gas getting to the carb, I pulled the line and she had plenty of gas.
Old 03-06-2005, 06:33 PM   #4
screamin_c102
screamin_c102's Avatar
Not tryin to be a smart ass, but the piston tops out in the bore on the exhaust stroke (180 degrees) as well as the combustion stroke (0 degrees). I'd double check that you are on the comp stroke and not 180 out before you get too far along. I know it sounds petty but I have done it many a time.
Just tryin to help.
screamin_c102 is offline   Reply With Quote
