i love summertime
want to fire up the 67 today, anything i need to do before i turn the key?
the truck has been sitting in the garage since last oct, full tank of gas with that gas stablizer in it...the battery has been inside sitting on a block of wood, so ill stick that back in the truck and should i be okay to fire it up or should i do an oil change first? any other things that need to be done? im sure i can just crank it over...but wanted to double check first
thanks, DEREK
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
Seasonal Poster
what I usually do is just crank it over for a while without giving it and gas just to let the oil start pumping through there. Once that's done with, just give'er a few pumps and turn the key...You should then hear a satisfying growl from the exhaust as gasoline is combusted in the cylinders and forced out through the exhuast manifold and down to the tailpipes.
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
its all about the +6 inches
actually, cranking it over on the starter will do more damage than getting it to fire on the first crank.
If you want to be annal, you could remove the ditributor, and run a primer tool in there...build up oil pressure, and then reinstall the dist and crank it up. While that is the best thing to do, you won't be doing much damage to just crank it up. I would run it for 30 min or so, bringing it up to operating temp, then drain the oil and pull the filter. As for your battery, the whole block of wood and cement draining the charge...it's BS. But I am willing to bet my left lug nuts that it'll need a charge. So IMO...charge the battery, pour a little gasolin in the carb, and let her rip. |
i love summertime
cool guys thanks
i love summertime
wow 15 posts to hit 4,000 saweet could happen in the next couple days!
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Has the 67 been fired??
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Insert key and turn clockwise
#8 | |
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
screamin_c10...you forgot to pump the gas.
Longhorn Man is right about batteries draining via the case setting on concrete or the ground. That applied to old, rubber-based cases that were used way, way back in the day. Hopefully, I wasn't alive then.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
i love summertime
yeah she fired right up, about 5 pumps of the pedal and it came alive...ran like a champ, let it run for 10 minutes then did an oil change. good to go now
while were on the topic dirt is actually what discharges a battery. the dirt on top of a battery will allow the posts to make connection and it turn cause a draw. the concrete floor thing is a myth
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
