Old 06-02-2002, 09:59 PM   #1
72chevyLWB
Got 20's????
72chevyLWB's Avatar
anybody with 85-87 with 700R4
Could you please measure your driveshaft length for me? it also has to be a long box. I need one that is right around 69" for my 72. I think one off these trucks should fit perfect since I have a 700R4 and longbox.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 06-05-2002, 07:18 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
A drive shaft off a LWB truck should work. The frames are basically the same. I have a SWB truck and the drive shaft not adding the yoke for the tranny is 57 inches. Do you have a 12 bolt on your truck? If so the 85-87 1/2 ton trucks have 10 bolt rearends. You will need a bastard U joint to bolt up the drive shaft to the 12 bolt. I just replaced mine with NAPA part number 372 in the yellow box. I replaced my original 10 bolt with a 12 bolt. My truck also has the 700R4 combo.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
