Amp gauge Question!!
I HAVE AN AMP GAUGE IN MY 82 C-60 AND IT IS NOT READING CORRECT! I MADE SURE THE HORN RELAY WAS GOOD AND I DO HAVE VOLTAGE FLOWING THROUGH IT BUT MY BIG CONCERN IS ARE ALL AMP GAUGE SET UPS CRAPPY? I AM CONVERTING IT TO A VOLT GAUGE AND JUST WONDERED IF I WAS THE ONLY ONE WITH ANY PROBLEM LIKE THIS! iF YOU TURN THE LIGHTS ON WHILE THE TRUCK IS RUNNING EVERY AMP GAUGE THAT I BOUGHT AND PUT IN THERE JUMPS AROUND A-LOT! THE VOLTAGE ALWAYS READS CORRECTLY! MIND YOU THAT EVERY GAUGE BOUGHT AND PUT IN WAS NOT PROFESSIONALLY TESTED! THANKS! I THINK AMP GAUGES ARE A BUNCH OF
1978 Chevy C-60 Pumper Truck! 1985 Chevy 4x4 project! 2002 Chevy Crew Cab DURAMAX 4x4!! ![]() 2002 Harley Road King BIG BORE STG. II, Thunderheader,Dfo Module! ![]() 2003 Chevy Malibu! |
North Coast, baby!
I can tell you that as far as light duty trucks go, Amp gauges were discontinued after 1977. I would have assumed that Chevy/GMC did the same thing with their heavy duty line up as well. Having said that, I would think that an 82 truck should have a Volt gauge in it.
Brad 79 Scottsdale C20 ![]() 350/350 3.73's Still running full CA smog gear! ![]() |
I have a 78 c-60 as well and it has a amp gauge too!! I already am converting to volt gauges in these trucks as we speak!! Thanks!
