![]() Join Date: Aug 2004
I just got my restoration packet today and started checking numbers for fun.. I had always thought my truck had a bed swap from long step to long fleet because of my VIN:
CE148S143xxx Should be a long stepside. Maybe rare, it is a big block cst.. I checked the glovebox sticker model code and it has CE10934, long fleetside. ![]() I'm pretty sure the glovebox sticker is original, it has a small sticker on the bottom with the salesman's name and old style phone # from a dealership in Garland. Has anyone ever ran across this sort of thing? I'm not real worried about the whole #'s matching thing, the original block was gone before I bought it. But I do think it's weird... Maybe some mixup at the factory, or a last minute special order??
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Can you decifer what bed came with your truck from the VIN? I thought you could only get that from the model code on the glove box sticker. I am not sure, but I am sure someone will pipe in.
What do you use to decode? I have only used this board's decoder and GMCPaul's decoder.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Hey ya'll, Watch this!
Maybe the glove box door got replaced.
Rick M. 72 GMC SWB Fleetside 25 Chevrolet Superior Series Truck 95 Mazda Miata 06 Dodge Charger RT http://ram92.ods.org/blog.html |
I think I just figured it out, the 4 in the vin just means it it a pickup (thanks Rod for your earlier post). That's what I get for reading the vin decoder in the LMC catalog. I always thought they had an extra # in there.
You got a 68 long bed fleetside.
09 of the model number tells you cab to rear axle dimension..in your case 54 inches...and if its a GMC they use the number 59 to mean 54 inches...thats just the way it is. 34 means a fleetside bed..which you have if the avatar is your truck. Basically its a 68 1/2 ton with a v8, fleetside longbox, built in St Louis. The 4 in the vin identifies it had a box..not what type..the model number decodes to the type" fleetside" code 34 and lenght 09 =54 inch.. so a long box...gets simple after you answer the question a couple hundred times..lol ![]()
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
