Old 03-06-2005, 11:48 PM   #1
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Battery draining...HELP!
I just charged my battery and put it back in the truck and it started up like a champ. Well the next day I went out to start it and well battery had drained down a little bit and well motor would barely spin and so it wouldn't start. I checked the voltage and it was at 11.2 volts. But the day before after I took it off the charger it was sitting at like 12.6 volts and all day it was sitting around that. So I am thinking something is draining the battery overnight. What could I do to track down what could be causing this? Also when I turn the key on to go to start it my voltage gauge will go up to about 10 volts stay there for a second and then shoot on up to 12 volts. Does everyone elses vehicle do this or is there something wrong? Thanks everyone for any help...Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 03-06-2005, 11:54 PM   #2
alpha_male0203
95 extended cab sportside
alpha_male0203's Avatar
There must be a leak.
Try the Picture.
If that works and you have a leak.
Then start to pull fuses.
Start by taking the door light one out. Leave that out. Then pull till the light goes off. When the light goes out that means thats what you have to go to there is a leak in that area.
I had to do this with the 81 its a pain.
Have you installed a new alt. or starter? If you have chack that first as well.
I hope this helps.
HINT. Helps to have help with you.
SHANE
95 Chevy k 1500
00 Chevy Silverado 1500
07 cobalt Old ladies car]
alpha_male0203 is offline   Reply With Quote
Old 03-06-2005, 11:57 PM   #3
784X4GUY
784X4GUY's Avatar
Thanks man I appreciate it. I will try it tommarow after I get off work and see if I can find it...Mike
Old 03-07-2005, 12:01 AM   #4
alpha_male0203
Your welcome. Hope that it helps for you.
95 Chevy k 1500
Old 03-07-2005, 10:57 AM   #5
784X4GUY
784X4GUY's Avatar
Oh, I forgot to mention I have not replaced the starter or Alt...Thanks..Mike
Old 03-07-2005, 11:17 AM   #6
784X4GUY
784X4GUY's Avatar
Well I went and checked to see if there was anything draining the battery and nothing the light never came on. The battery that is in there is brand new and now it seems like it can't hold a charge for nothing. Do you think the battery is just junk, can batterys just stop working like this? Thanks...Mike
Old 03-07-2005, 12:10 PM   #7
Phuloi68
Is the alternator charging the battery?
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 03-07-2005, 12:25 PM   #8
784X4GUY
784X4GUY's Avatar
When I jump the truck, and get it running. Yes, the alt will charge the battery it will go up to like 14.5 volts...Mike
Old 03-07-2005, 08:03 PM   #9
alpha_male0203
Do you have tester for the battery to see if its good. if not chare it then take it to a place that can. That can tell you if its bad. Sorry that what i said before wasnt it.
Shane
95 Chevy k 1500
Old 03-08-2005, 12:10 AM   #10
784X4GUY
784X4GUY's Avatar
I've got ya, thanks for the help...Mike
Old 03-08-2005, 02:20 PM   #11
hotrodhomi
hotrodhomi's Avatar
test the cells with a battery hydrometer. If one cell is low, get a new battery.
hotrodhomi is offline   Reply With Quote
Old 03-08-2005, 08:28 PM   #12
784X4GUY
784X4GUY's Avatar
Yup that was it yall, it just had a bad cell...Thanks..Mike
Old 03-08-2005, 08:35 PM   #13
hotrodhomi
hotrodhomi's Avatar
glad to see it fixed.
Old 03-08-2005, 09:33 PM   #14
784X4GUY
784X4GUY's Avatar
Yeah, a lot easier fix than I thought it was going to be lol...Mike
