Old 03-07-2005, 02:08 AM   #1
1STtimePRo'71
1STtimePRo'71's Avatar
CD Player
I'm ready to install some music into my truck and have 2 questions. Prolly pretty easy but, where's a good place to draw ignition power for the cd deck? And where is the best place to ground this? I should say that there was no radio in it when I bought it and there is no harness or speaker wires under the dash. So i'll have to run new everything. I guess I'm just curious to see if anyone else has tackled this. Also any other pointers or things that I shouldnt forget? Oops thats three!
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 03-07-2005, 02:20 AM   #2
4x4Poet
Your oem fuse panel should have a few unused male blades awaiting females. Check for one that provides power with the ignition & acc on. Easy to run your power wire from there with no splicing into the factory harness.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-07-2005, 03:08 AM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I ran the battery wire through the firewall and straight to the battery,lost all the alt whine when I did.Power wire to the fuse block,and ran the ground to the plate under the steering column.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-07-2005, 08:28 AM   #4
1STtimePRo'71
Great thanks guys.
-Cory
1967 2 Wheel Chevy
