06-03-2002, 12:28 AM | #1 |
how to separate outer bedsides from inners ?
on fleetside long beds has anyone separated the outer sides before, i know pont has i think, ayone else ? how many spotwelds and where ? i need to snag these sides off this bed since they are clean no rust, so i can sell them or whatever and scrap the floor and rest of whatever else is trashed
thanks Last edited by Fast68Chevy; 06-03-2002 at 12:32 AM. |
06-03-2002, 09:07 AM | #2 |
bed sides
the sides unbolt there are two tack welds at the back were tail gate mounts. did you check my post under fast poll?will you be there during the day this week?let me know so i won't drive over and you not be there.
06-03-2002, 09:11 AM | #3 |
Also the inner wheel tubs bolt up under and inside the wheel wells, does that make sense?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
06-03-2002, 01:49 PM | #4 |
Progress = 0%
I think he means separating the inner and outer skins, not removing the whole bed side. Right?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
06-03-2002, 09:26 PM | #5 |
mark, i will be here all the time, i wont be here tuesday from 1-2:30 or so, funeral to go to.
otherwise wqil be here all the time, only gone for bits of time at a time to go get stuff or whatever yeah i mean removing bedside skin outer one only looks like are tacks inside the arches too for the filler deal in there thanks for any other info, i hope to be pulling 71 out of shed soon to dismantle/torch it and put aunt's trans am in there to store it, i got farther along on cutting up 70 shorty today than i thought i would thanks |
06-06-2002, 11:35 PM | #6 |
ttt, need to know details from someone who has removed outer bedsides
thanks |
06-06-2002, 11:46 PM | #7 |
I have done this. There are about a million spot welds along the top rail if I remember correctly. I I had to peal the outer panel lip up. It is ALOT of work to do. I havent mated up the good inners that I was trying to save with a decent outer yet. I kinda doubt that I ever will put them back together, I think it would be alot of work and wouldnt turn out all that good. Probably easier to look for a bedside with both good inners and outers.
06-07-2002, 12:33 AM | #8 |
My dad's 68
try a air chisel..........i guess so............fairly cheap
Jack
Jack M. 67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts ****************************** 88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires 4 12 inch Lightning Audios ****************************** 87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ****************************** Dad's truck 68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more ****************************** grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver* ****************************** 84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames ****************************** S/N=BIGGYTYME@aol.com (hydros) "No fat chics, truck will scrape" |
06-07-2002, 12:01 PM | #9 |
hmmmmm........ crappy....
well reason i ask is because i got pair of longfleet sides that are no rust, but couple dents.. hmmm.... was gonna see about selling them and not scrapping, but oh well,... thanks |
06-07-2002, 02:18 PM | #10 |
To remove the skins you have to drill out about 100 spot welds on each, bend and pry the crap out of each and try to not bend the crap out of each. The amount of time and hassle would be about 5 times more than if you just removed each bedside, Plus i've never heard of anyone just replacing a bed skin, most people will repair the inside part to save the hassle.
06-07-2002, 07:09 PM | #11 |
"Ochre Ogre"
If they are that nice you would be better off to cut them up as patch panels. They should still be better than using re-pop panels.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
06-12-2002, 01:58 PM | #12 |
The way I see it, I would cut the inside panels about 3-4 inches down the side. That way you could use them with some inners that you cut above that and over lap them. Then screw them together up near the top inside under the rail. This would hide the seam very well.
06-13-2002, 02:17 AM | #13 |
guess will have to use the 7" cutting wheel on the big ass right angle drill deal,...
need new wheel first though, or maybe i have some here, hmmm... i forgot if i got extras last time i went to Big R store,. thanks guys |
