Now the others dig........
![]() Join Date: May 2002
cutting front coils to drop
I just want to get a two inch drop up front on my 68, I have some coils I pulled from my parts truck....or whatever is left. I know you can cut off one of the loops. BUT how many would I have to cut to acheive a two inch drop....or as close too. Also when replacing the shocks with shorter ones do I need to buy special "drop shocks" or how would I go about getting some that are shorter???
Thanks guys...
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
1 coil is 2 to 2.5 inches. Stand the springs side by side then cut the second one at the same height. Maybe a little more or less than one coil on the second spring. If you dont do this the front will lean to one side.
I see your not to far from Austin. I have a cut pair you can have if you want to make the trip. Frank
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
thanks frank......I have a set I'm gonna cut myself....a hack saw or grinder should work right????
P.S. I am interested in lowering blocks and ubolts for the rear, of you got any 2-2.5 inches is good.....give me a few weeks and if you want to let them go I can take them of your hands then!!!
Thanks Frank.
#5 | |
Happy to be here
![]() Join Date: Mar 2000
'72 1/2 ton short box 468 BB forged crank/rods/pistons full roller. Msd 6 AL ignition turbo 400 tci. 2800 verter ladderbar/coil rear with currie built ford 9'' rear, 4.11 gears custom built rear frame tubbed, 33/19.50/15 rear m/t. m/t skinnies in front still under construction |
