03-07-2005, 12:05 PM | #1 |
More Cowbell....
QUICK...Grab a tape-measure
Can anyone please give me the measurements for a stock (or close to stock) radiator?
I only need width and height. THANKS, ERIC
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
03-07-2005, 12:07 PM | #2 |
Resident Curmudgeon
It's not that simple. I6 or V8? 2, 3, or 4 row?, Height should be same but width won't
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-07-2005, 12:09 PM | #3 |
More Cowbell....
3 row V-8.
03-07-2005, 03:14 PM | #4 |
More Cowbell....
Nobody has a tape measure??? Yard stick? Guesstimate??
03-07-2005, 03:44 PM | #5 |
I have a 4 core at home I can measure for you tonight if no one else replys.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
03-07-2005, 03:58 PM | #6 |
More Cowbell....
Super, thanks.
03-07-2005, 04:08 PM | #7 |
fixer of 72 GMC LWB
okay, its about 35 wide by 19 high, 2 1/2 thick... v-8 3spd.. radiator
03-08-2005, 03:45 PM | #8 |
my gas saver
hey putter, mine`s about 29" wide (on the inside mounting surface). should squeeze both fans right across it.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
03-08-2005, 04:58 PM | #9 | |
http://community.webshots.com/user/hotrodhorn |
03-08-2005, 06:20 PM | #10 |
fixer of 72 GMC LWB
I measured the outside width to include the endcaps... whether it came with that one It sure looks as it came that way, but I am not 100% sure as I keep making discoveries, not all bad, but my 305 turned into a 350...
03-08-2005, 08:20 PM | #11 |
20' Daredevil (Ret)
Putter, I just measured my recently-removed OEM V8 3-row. Height of core is a fat 18 1/2", and width to outer edges of the tanks is 34", plus about 3/4" extra bulged out where the lower hose attaches. If you need any other measurements, just holler.
