Old 03-07-2005, 04:02 PM   #1
Prerunner1982
Prerunner1982's Avatar
88+ suspension on 82 .....
ok... i read the thread on putting 88+ spindles and brakes on a pre 72... amazed it worked like it did...
i dont need the power brake conversion... already have those. I do however would like to use a set up 88+ lift spindles.. I plan on swapping to a 3/4 ton rear end, and using a 6 lug front. my question is, will the lower ball joints bolt up to my stock lower control arm or like the pre 72s will i have to go with a 3/4ton arm? will an 81-87 3/4ton lower control arm work? will the upper ball joints fit the stock upper arm?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
