Old 03-07-2005, 06:18 PM   #1
1986Silverado
What I drive
1986Silverado's Avatar
how to cut dash to...
install a radio? Got the dash bezel cut yesterday but did not want to use tin snips and ther hacksaw did not seem to fit. Any suggestions?
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 03-07-2005, 06:50 PM   #2
Russell
Professional Grade
Russell's Avatar
Sawzall
Or, if you are a wimp, dremel could work too
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-07-2005, 07:15 PM   #3
Destructo
I used a dremel cause I wanted it to be accurate! I would also use a pneumatic cut-off tool had I had one when I did mine, MUCH quicker than the dremel and would be easy to cut a straight line.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 03-08-2005, 12:04 AM   #4
TrainD5115
North Coast, baby!
TrainD5115's Avatar
For those of us who do not have any cool power tools, I used a large utility knife with a small saw blade. After cutting the rough outline for the radiio I went back around the edges with a good size file to smooth things out. Do a few test fits to make sure you don't take too much out.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 03-08-2005, 09:23 AM   #5
ste-pel
i used a jig saw
ste-pel is offline   Reply With Quote
Old 03-08-2005, 11:25 AM   #6
79C10
I used a exhaust cutter (pnematic cutter) for mine then filed down the rough spots
79C10 is offline   Reply With Quote
Old 03-08-2005, 11:32 AM   #7
1986Silverado
What I drive
Have no dremel or pnematic cutter, so looks like I will be getting some metal blades for the old jigsaw
2006 Chevy Equinox
Old 03-08-2005, 11:47 AM   #8
Ric83
Ric83's Avatar
We just used a hacksaw blade on my dad's truck.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 03-12-2005, 10:14 AM   #9
87_Blazer
Getcha' Pull!!!
87_Blazer's Avatar
yep just use a hachsaw blade; maybe modify it to some sort of pre-historic handle like i did and you will be fine!!
87_Blazer is offline   Reply With Quote
Old 03-12-2005, 10:40 PM   #10
ste-pel
vicegrips for good for a handle sometimes
Old 03-12-2005, 10:51 PM   #11
87_Blazer
Getcha' Pull!!!
87_Blazer's Avatar
very true....very true
Old 03-12-2005, 11:41 PM   #12
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
Cutting the dash?
HERESY!!!!!!
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 03-13-2005, 02:05 AM   #13
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
I tried snips and they worked ok on one side, but the sawzall made quick work of the other. Kind of hated using a big ol saw just to make a little cut. A jig with a metal cutting blade should work.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
