03-07-2005, 06:57 PM | #1 |
Just got Diagnosis from Mechanic...suggestions???
Well you guys probably know my 72' K-10 either dropped the tranny or rear end and I just got the call....REAR END exploded so to speak. I have little to no experience with this so I'm looking for advise??? Did y truck have a posi in it...I think it did?? Do I get a new 3.07 eaton posi for it??? Any suggestions would be greatly appreciated!!! Oh...how much does a problem like this cost???
Alex
Alex 1971 Lil' Red 350 SBC 700R4 |
03-07-2005, 08:38 PM | #2 |
Too many is never enough!
I had my 10 bolt on my '90 Jimmy rebuilt with new everything. Cost me $1100!! Basically decided I'm a dumbass and should have just grabbed one out of the junkyard. Will never do that again! Could have bought a Dana 60 front diff for that! Anyway, watch out. You could drop a grand on rebuilding it and you still wouldn't be able to get more that $200 for it if you tried to sell it. Definitely get a solid estimate before the work is done. My parts were pricey as I did ring and pinion, carrier, spider gears, bearings, etc... Ads up real quick. I'm not saying I got ripped off, I'm just saying I should have had more sense than to spend that much money on a 1/2 ton rear diff.
Hmmmm....maybe it's time for you to upgrade to 1 ton stuff! 8 lug bullet proof. 4.10s with 35s would be sweet!
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
03-08-2005, 03:18 AM | #3 |
Are you running 5 or 6 lugs?
03-08-2005, 03:47 AM | #4 |
just buy a good used one and slide it in there.
72 GMC sierra 3/4 ton 402 bb 68 GMC 3/4 ton 2010 camaro rs: daily driver |
03-08-2005, 11:13 AM | #5 |
6 lugs
03-08-2005, 11:24 AM | #6 |
Still drivin' a Rat Rod
I'd go with a used one too.Save yourself a bunch of money.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
03-08-2005, 11:32 AM | #7 |
Rear End
You can also go with a 73 & up 12 bolt rear end. You would have to relocate the spring perches & shock mounts for it to bolt up, but you also get larger brake drums for beter stopping. ( Make sure you get the correct gears to match the front )
Gary |
03-08-2005, 11:47 AM | #8 |
So how do I determine what the ratio is that is busted and whether it is a posi unti or not? Did the 72' K-10 come with 3.07 posi unit?
03-08-2005, 12:32 PM | #9 |
Rear End
I know they came with 3:07's, if it was originaly a posi it should be on the option sheet in the glove box. Other wise ( If something is broken inside ) you'll have to look at the carrier to see if it's a posi. There would be spring packs or clutch plates in the carrier if it's a posi. You can determine the ratio by the numbers on the ring gear. Example ( 41 DIV By 11 = 3.73 ) Not sure what the numbers are for 3:07s. Also there maybe a tag on the front diff under one of the cover bolts, on this tag it will give the gear ratio.
Gary |
03-08-2005, 01:06 PM | #10 |
Thanks guys!!!
03-08-2005, 01:29 PM | #11 |
I spent 1100 on my rebuild for the 67. New gears rebuild the posi bearings seals. If you are keeping the truck it would be worth having it rebuilt. The eatons are a great posi. They are also rebuildable.
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-08-2005, 01:51 PM | #12 |
Apparently the original unit is NOT a posi unit....should I put a posi back in this K-10???
I believe I am keeping this truck Yes! I will go with Eaton for sure!!! I guess seeing how I have to rebuild this rear end I can make it 3.07 or 3.73....what should I do there??? I'm really in the dark in this area...never done this crap or been down this road before.
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 03-08-2005 at 01:56 PM. |
03-08-2005, 02:06 PM | #13 |
Remember that the ratio in your rear diff has to match the ratio in the front, if not, when you put it in 4x4, the front will be trying to go faster than the rear. I say rebuild her with your current ratio, and a posi.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed Last edited by 1971 Cheyenne; 03-08-2005 at 02:14 PM. |
03-08-2005, 02:08 PM | #14 | |
03-08-2005, 02:14 PM | #15 |
I kinda thought it was going to be the rear when I talked to ya. Sorry to hear it. Contact www.randysringandpinion.com and see if they can help you out at all Alex, I forget the name right now, but one of the guys there is a fellow board member.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
03-08-2005, 02:33 PM | #16 |
Cool Les....just found out I have 11 / 44 ....so I guess it's a 3.73 rear end.
03-08-2005, 02:55 PM | #17 |
Gear Ratio
Alex:
That dosen't sound right, 44/11 = 4. Recheck the numbers on the tag or the ring gear. You have to have the same gears front and rear. ( 3:73's are 41/11.) The higher # is the number of teeth on the ring gear and the lower number it the number of teeth on the pinion gear. You could also mark a tooth on the ring gear, slowly turn it and count the teeth. But there should be numbers on the ring gear that indicate the # of teeth. Gary |
03-08-2005, 03:08 PM | #18 | |
http://cgi.ebay.com/ebaymotors/ws/eB...category=33731 Mechanic shop just said $1600.00 for them to rebuild it with an Eaton posi and new gears & bearings....Are they ripping me off??? The above ebay auction for the Eaton posi with ring and pinion, bearings, & everything needed is roughly $600 to my door.....so $1000 for the labor??? Is that right??? Your thoughts are appreciated tons...don't want to get taken on something I don't know much about. Thanks in advance!!
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 03-08-2005 at 03:14 PM. |
03-08-2005, 03:26 PM | #19 |
$1,600
Alex;
That sounds high to me, but I would do the job myself and just pay for the parts. For that kind of money they should be replacing just about everything. Posi carrier, ring & pinion gears, carrier bearings, pinion bearings, axel bearings, axel seals, cover gasket, shim kit and lube. But the most important part is they set up the gear depth & back lash correctly or it will all be junk in a short time. ( New crush sleeve also ) Gary Last edited by CUSTOM/10; 03-08-2005 at 03:32 PM. |
03-08-2005, 03:41 PM | #20 |
FARMER/RANCHER
bring it up here to SD and I'll rebuild it for ya! I just rebuilt my mom and dad's 2000 chevy suburban's rear end, ended up costing around 400 for used parts, and new pinion bearings. not too hard of a job, ya just have to take your time. pay me the 1200 and I'll do it for ya.
1972 chevy super, long box, 402 big block (2,000 miles on rebuild) 2wd tach, tilt, tool box on bedside, a/c, sliding rear window, orange and white. 1972 Chevy Blazer 2wd, tach, tilt, a/c, my first engine overhauling experience, Orange, with white top 2006 Gmc Sierra, XM, Z-71, dark blue, onstar, leather, rear entertainment (audio only) heated seats, (the wife loves that feature) upgraded tires immediately after purchase to Goodyear Wrangler AT/S (hate those rock throwers that come from the factory) BWC |
03-08-2005, 03:41 PM | #21 |
So Gary is that kit on Ebay...all the parts??? Cause I just found a "Differential" shop that will do the R&R for $300 bucks...quite a difference!!!
03-08-2005, 03:58 PM | #22 |
I just had mine done. New Eaton carrier, bearings, OEM ring and pinion - it cost around $1200. I probably could have done it myself, but there are some critical measurements - bearing preload, and pinion depth that I didn't have tools for, and didn't have the time to 'trial and error' it.
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
03-09-2005, 02:13 PM | #23 |
OK...with all you guys help I have got a deal going to completely rebuild my rear end for $900 bucks!!! I bought the complete 12 bolt Eaton Posi kit over the phone with the upgraded blue box Motive ring and pinion gear-set all the bearings , seals , shims....for $600 bucks, delivered to my door.
I am super happy...you guys just helped me save $700 bucks!!! Does this board rock or what!!! Thanks guys!!!
03-09-2005, 02:41 PM | #24 |
$700? Wow - looks like the board will be getting a new server
By the way, that is an UGLY truck in your avatar, but I think I've commented on that before.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
03-09-2005, 03:02 PM | #25 |
Yea it's ugly alright....It's not my truck in the avatar...that's what My truck is supposed to look like after it's resto.......BUT....something has come up and the K-10 may be going up for sale...kinda sad today.
