Old 03-08-2005, 12:17 AM   #1
Ron
Ron's Avatar
Cargo light
Where does the cargo light switch mount and what does it look like? Where does it get its power from, light switch, batt? I'm wiring up my 72 Scout cargo light and I want to use chev parts. Thanks
'69 SWB
'76 International "Terra"
"Hooked on holiday beer"
Ron is offline   Reply With Quote
Old 03-08-2005, 12:30 AM   #2
Low69CST
It's a small stainless (?) piece with a black switch mounted under the incab light in the back of the cab. I think it gets it's power from an open source in the fuse block. Not sure though. ECE sells new ones.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 03-08-2005, 12:34 AM   #3
72402
Gets power from the dome light. Small slider type switch below the dome light. Cargo light only works when dome light is on.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
