Senior Moment
![]() Join Date: Mar 2002
What determinds the use of a Long or Short water pump on a big block convertion. I have 72 motor mounts so what pump would I use.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
I need another Barley Pop
I would think you can use long or short. I have a big block in mine that originally had a short water pump but now has a long water pump. Just make sure you have radiator clearance for the long water pump. It's easier to get brackets and pulleys for the long water pump if that matters to you.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
CCRider
Short was original,so use short if that is important. Long is off 73 up,but is much easier to find and actally better,IMO. On both the big block and the small block when they went to the long water pump they moved all the accessorys in closer,so the setup uses shorter belts,which is much better if you want to build a high reving motor. A long water pump setup works best if you set the motor back about 1.5 inches on a 2WD but you can make it work without doing that.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
SKINNY TIRES RULE!
I have a small block with a short on it. I'd like to convert it over to a long when the pump goes out. The belt to the alternator is much longer and slips easier on the short pump than on the long.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Senior Moment
Tom
If I set the motor back 1 1/2 inches then I have to move trans mount and cut driveshaft RIGHT? If I dont move it back what problems do I run into? Thanks for the info Steve
CCRider
If you don't move the motor back a stock clutch fan will be very close to the radiator [or actally hit the radiator depending on what thickness radiator you are running] and the fan will be too far in the shroud. So you can use a flex fan with a shorter spacer,[which I do not recommend,they have been know to come apart] or switch to an eletric fan. Moveing the motor back works best and looks completly stock when finished IMO.
