03-08-2005, 10:26 AM | #1 |
trailing arm bushings
What level of effort is required to change these on a 1/2 ton long bed?
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
03-08-2005, 10:39 AM | #2 |
Watch out for your cornhole !
Remove the arm and clamp it into a vice. Then, run them out with an air hammer and flat bit.
Getting the big bolt out to remove the arm is the hardest part.
03-08-2005, 10:39 AM | #3 |
A fair bit, the sleeve for the bushing in stuck in the arm real good, and the rubber is stuck in the sleeve even better. What I always end up doing is basically setting the rubber on fire with a cutting torch until it shrinks enough to slide out, by that time the arm is good and hot so it will help getting the sleeve out but sometimes I still have to cut it in half and work it out. BTW you can get the bushings from your local GM dealer still.
03-08-2005, 12:09 PM | #4 |
I Usually Just Take My Trailing Arms & New Bushings Down To My Local Driveline Shop. He Presses My Old Ones Out, & My New Ones In In About 3 Minutes. I Buy Him A 12 Pack, & Were Both Happy. John
(any Good Sized Arbor Press Will Do The Job Lickety Split)
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
03-08-2005, 03:04 PM | #5 |
I took mine, turned them on their side, and burned them out with a propane torch. Once the arm was cooled I cleaned it up with some brake cleaner, put some lube in there, and drove in the new ones.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
03-08-2005, 03:47 PM | #6 |
fire??
I have set fire to them as well before and it works fine. However, the last time I did this I had just parted out a truck and my torches were out of gas . I simply took a small drill bit in the cordless drill and drilled through the rubber on the outside edge a couple times and hammered them out. It wasn't as cool as setting them on fire but it worked. Just my .02
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
03-08-2005, 04:15 PM | #7 |
i second the pyro technique. then you get to upgrade to poly bushings by using the existing shells.
