Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-08-2005, 12:19 PM   #1
Nolowrider
Nolowrider's Avatar
F/S Crane cam
I have a Crane cam for a SBC for sale. It is used, but I have only driven the truck for about 30 miles. It it just not the cam I wanted. I bought it as a kit, so it comes with new lifters. It is still in the truck, but I will pull it out if someone is really interested in buying it. The truck is just a weekend driver. I did the correct break-in procedure as per Crane. I just don't want to yank it out and leave it sit on the shelf if someone could use it. I paid $145.00 for the kit. I would like to get $90.00 plus shipping. I am in zip code 70037. This is it http://www.cranecams.com/?show=brows...52&lvl=2&prt=5
Nolowrider is offline   Reply With Quote
Old 03-08-2005, 02:09 PM   #2
locab36
locab36's Avatar
Thats the same cam I just put in the 350 for my 84 C10. I really like it. I have a RV cam in my 69 short step and its tame. This crane cam has just enough lope @ idle and is very divable w/no effect on vaccume. It has a good pull too.
John
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 03-08-2005, 03:43 PM   #3
Nolowrider
Nolowrider's Avatar
Yea, it is a good cam I just wanted something with a little more lope. Crane told me that this was the biggest with a stock stall converter. Which I found out is not true. I am going to try a 280.
Old 03-12-2005, 01:18 AM   #4
68Bowtie4x4
68Bowtie4x4's Avatar
nolowrider,
I'm interested in the cam. Let me see what my rpm is going 60 mph and I'll get back to you ASAP. Can you figure shipping to zip 97886?
Thanks,
Doug
72 Chevy Cheyenne K10 4x4 LWB, 4" lift kit, 350/350/NP205, rebuild in progress.
68Bowtie4x4 is offline   Reply With Quote
Old 03-12-2005, 04:31 AM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Dont reuse the lifters
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-31-2005, 11:51 AM   #6
70short/step
70short/step's Avatar
You can reuse lifters as long as he marks them so when they are reinstalled they are on the same lobe that they were on before. It wont hurt anything!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 03-31-2005, 02:48 PM   #7
Nolowrider
Nolowrider's Avatar
I have just the cam, no lifters. I reused the lifters since I had so few miles on it. If you don't really know how many miles are on the cam and lifters, I would get new set. It is worth the extra effort. I knew mine was new, so I took the chance. No problems.
Old 03-31-2005, 03:19 PM   #8
MylilBowTie
Right turn Clyde
If its for the same block that the lifters and cams where broke in on. But If its not there will more likely than not cause a problem. Its really not a good practice to reuse lifters or camshafts but really used lifters that aren't mated to the same block or cam that it was broke-in with. Im not trying to mess up anyone's sales or anything like that but most of this stuff is commonly known stuff. See what everyone has to say over in the engine and drivetrain forum about it.
Old 03-31-2005, 03:32 PM   #9
Nolowrider
Nolowrider's Avatar
68Bowtie4x4-IF you were to get the cam, get a new set of lifters. You can get a good set for $40.00-$50.00, maybe even cheaper. Since you would have the engine tore apart, just through a new set in there. I swapped cams on the spur of the moment, so I didn't have a new set of lifters laying around.
Old 03-31-2005, 03:33 PM   #10
70short/step
Have to disagree with Mylilbowtie. The wear on the lifter that is important is the face surface of the lifter not the sides where it sits in the lifter bore. So as long as the cam and the original lifters are used together on the same lobes there is not a problem as stated before.
70 Short/Step
Old 03-31-2005, 03:38 PM   #11
Nolowrider
Nolowrider's Avatar
I agree with 70short/step.
Old 03-31-2005, 04:01 PM   #12
MylilBowTie
Right turn Clyde
Lifter bores can influence the lifter but plays a smaller role in the contact. The bottom of the lifter and the cam is the most important. If the lifter doesn't rotate like it should its just going to wear the cam lobe to nothing if it isn't fixed. For 160.00 you can get a new camshaft and lifters, its not that much. Those can mess up also but a lot less likely verse used parts. When your down to one vehicle down time is a big pain. Especially when you have to fix things again that weren't done correctly in the first place. Camshafts can be used again without much trouble as used lifters.
Old 03-31-2005, 05:23 PM   #13
70short/step
This is my last post on this subject....But how can the lifter bore do anything to make the lifter not work in another block?? In that thinking then you would need your lifter bores machined to the lifters. You dont have to mic the diamater of the lifter bore to the lifter. The lifters dont know what hole or block they are going in. The only wear is on the face. Period! Of course If you have a crazy amount of miles on any engine part i would not reuse them, But we were talking about a cam and lifters with only a few miles on them.
70 Short/Step
Old 04-01-2005, 02:33 AM   #14
grovmister
If the cam is not sold-- put me in line.
Shipping to 97401?
72 Chevy C10 LWB 15X8 Chevy Corvette style rallys.
72 Chevy C10 LWB Truck Ralleys, tach, tilt, hidden hitch
72 Chevy Grn C20 Custom Camper 120K Newer Style Truck Alloys, Dailey Driver.
grovmister is offline   Reply With Quote
Old 04-01-2005, 06:05 AM   #15
MylilBowTie
Right turn Clyde
There isn't really anything else to say about it. Reread everything, I misunderstood and thought the sale included the lifters but this is not the case.
Lifters alone that come with the kit list at 88.98. That's 75% of the total cost of the cam and lifter kit itself and almost 30% more than the cam alone brand new sealed in box.
Old 04-01-2005, 09:59 AM   #16
Nolowrider
Nolowrider's Avatar
I just re-read my original post and I guess it does say with lifters. I should have went back and changed after I used them. I just kind of forgot about the post. My fault and I do apologize for the misunderstanding. SInce I F'ed it up, how about $70.00 plus shipping?
