03-08-2005, 03:00 PM | #1 |
Maximum wheel backspacing
I plan to buy a set of Centerline Wheels 15x10" (back) and 15x8" (front) for my truck. I want the tires to be as far under the truck as possible. Does anyone have experience in the maxium backspacing for both front and back
thanks jason |
03-08-2005, 04:25 PM | #2 |
That completely depends on the size of tire you are going to use. Not sure on a widebox, but for my '68 the stock axle is 63" mounting flange-to-mounting flange. The width of the stepside bed on the inside of the wheelwell is 50-1/4". To be safe you should have 1" of clearance on the inside of the tire.
'68 Chevy Stepside in Frame-up Restoration process. 292 CID Clifford Performance Modified T56 6-speed Tranny Slammed, Custom IFS and IRS Money?...Too Much! |
03-08-2005, 07:04 PM | #3 |
Tire Size
I am looking at a 50 series in the back and a 60 series in the front. I don't know all the new numbers yet. I think measuring is the best way.
03-08-2005, 07:19 PM | #4 |
my gas saver
usually 4.5" is a good standard, maybe 5". i know both of those are good for sure but you may be able to get 5.5" or possibly more with a small sidewall.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
03-09-2005, 08:49 AM | #5 |
Forever Grateful
I know you can fit a 15 x 12 w/7.5 "of BS.....so if you have a 10" rim you could have 5.5" of BS....
R.I.P Dad 04-07-42 - 05-27-09 |
03-09-2005, 09:00 AM | #6 |
If you mini-tub or tub it you can run alot more back-spacing so that makes a difference as well.
03-09-2005, 09:12 AM | #7 |
67-72 parts collector,…
Wheel diameter makes a difference on the front wheels. The rear is not as critical. You can run a 5" backspace up front with 17's,... but not with 15's. (rubs on the lower a-arms) Stay with a 4" backspace on the front.
