Junior Member
![]() Join Date: Jun 2003
Wheel cylinder
Does anyone know the rear wheel cylinder bore diameter for a '72 C10?
Thanks |
Junior Member
wheel cylinde bore
I was told there were two sizes available and the rearend I am using came without cylinders.
Junior Member
wheel cylinder
Lets try another way, does anyone know a part number from O-Reilly's, Napa etc. for rear wheel cylinder for '72 C10?
Try www.rockauto.com follow the direction and find the part numbers you might need.
It will give you part numbers that can be crossed over. It also gives you multiple choices as to manufacturers, Raybestos, Wagner, AC Delco, ect Just my .02 ![]() Last edited by GMC1tondually4dr; 03-10-2005 at 12:59 PM. |
Junior Member
Watch out for your cornhole !
O-Reilley has a good website where you can look up your own part numbers. I do it myself to keep the local monkeys from giving me the wrong parts.
I'm not saying all O-Reilley parts guys are monkeys, but I'm just lucky enough that all the ones at my local store are.
