03-08-2005, 05:25 PM | #1 |
Keepin an eye out
supertrac bar kit or adj. panhard bar....
on a 5" coil rear drop?, '70 C-10.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
03-08-2005, 05:34 PM | #2 | |
Seņor Member
03-09-2005, 12:37 PM | #3 |
one set closer
will a adj. panhand bar work with a 6 inch coil drop.
03-09-2005, 04:37 PM | #4 |
If you only do the panhand bar the mount point will be to high on the rearend. This may cause the rear to go from side to side as it travels up and down. The ECE kit mounts the pivot point on the passengers side rearend mount.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
03-09-2005, 05:42 PM | #5 | |
Seņor Member
03-11-2005, 08:24 PM | #6 | |
