Old 03-08-2005, 06:19 PM   #1
SS79chevy
? for you 5/7 droped truck guys
could i get some of you guys to post some pics of some 5/7 droped stepside trucks with eny rims but would like to see some tork-thrust 2s (sp?) or some weld pro stars and how wide fo back rims can you put up under the back and what front rims do i need how wide back spacing etc do you need for the front with that drop so nothing will rub?
Thanx for eny help
1979 chevy c10 short bed step side
BBC in the works
SS79chevy is offline   Reply With Quote
Old 03-08-2005, 08:52 PM   #2
TIMSPEED
TIMSPEED's Avatar
you can run 9½" in the back, with 5½" of BS on a 7" drop.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 03-09-2005, 04:07 PM   #3
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
yup, and the front you can run a 7" with 4" BS with a 5" drop
here a pic for you
http://67-72chevytrucks.com/vboard/s....php3?t=135524
Grande Rojo is offline   Reply With Quote
Old 03-09-2005, 05:13 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
Nice truck! While you're on the subject of 5/7 drops, how much wheel and tire can you stuff under a Fleetside? I've got a 15x10 widened Rally with a 4.5 backspace with a 285/70-15 with a 6" drop, and it looks like it will be ok. The truck is in the mock-up stage, so I haven't had the opportunity to drive it yet.
________
Yamaha bruin 350 specifications
chevyrestoguy is offline   Reply With Quote
Old 03-09-2005, 05:41 PM   #5
Grande Rojo
paper or plastic?
I dont know if the stepside fenders are in the same spot as the fleetsides but here is a pic of a 285/70/15 on a stock 15x8 rally
Old 03-14-2005, 02:04 AM   #6
SS79chevy
Thanx guys but are you sure you cant fit eny wider rims then 9.5 on the back like i have 15X10.5s with 275/60/15s on the back of mine and i think if i had about a 1/2 inch or so of it more on the back side it would tuck em
grande is that a true 5/7 drop? what kit did you use and what it cost? did you have to C-notch the frame or you just do it just in case?
thanx
BBC in the works
Old 03-14-2005, 08:45 PM   #7
Grande Rojo
paper or plastic?
thanx
yes its a 5/7
I dont remember what brand but I did buy it from stylin concepts though.
The front has spindles and springs the rear has a flip kit/shackles and notch.
If you just do the flip you should not need a notch but if you add shackles I would do the c-notch.
Remember though, it may not look too low but those tires are about 30"-31" tall on the back.
