Old 03-09-2005, 06:10 AM   #1
67chev
67chev's Avatar
Question Steering Column Question
I just got my new column in today and it has the original "U" shaped plug. I am putting a Painless kit in my truck and it only has the flat plug. What are my options here?? I have an adapter, but it if for the other way around..."U" plug with male ends, going into a flat plug for a van tilt that I had. Do they make an adapter that goes the other way around?? If so, does anyone have an extra one laying around?? Any info appreciated.
"SicStee8" Chevy SWB Fleetside, in progress...500 HP 383 w/TriPower, 700r4, 3.73's, Lowered, Shaved Driprail/sidemarkers/handles/ant, Gonna rock!!
'96 Chevy Tahoe 4X4
'84 Chevy C/K10 4X4 (FOR SALE)
67chev is offline   Reply With Quote
Old 03-09-2005, 11:35 AM   #2
COBALT
COBALT's Avatar
You mean for the turn signal wire harness? Yes, they make an adapter:
http://www.chevyduty.com - Includes it with their replacement turn signal switch (53-510) - Item on the right in the pic.
You could print this pic, and take it to a parts store and see if you can find it - or call chevy duty and see if they will sell you the adapter or could tell you where to get it.
Someone else on this board may know how to get one local to you.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-09-2005, 02:17 PM   #3
Bob Moore
In stead of the REVERSE adaptor you mentioned(which I don't think anybody makes) you might just replace the turn signal switch with a newer flat style. Many of the vendors should be able to help you out.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-09-2005, 02:47 PM   #4
71swb4x4
71swb4x4's Avatar
You can do 1 of 2 things, you can cut the flat one off one in the junkyard, and then solder all of your wires up to the wires that are hanging out.
You can also get an empty flat plug, and the terminals that go inside. You can put the terminals on the ends of your wires and they slip right into the plug. I found the terminals at a local auto repair shop that specializes in vehicle electronics.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
