Old 03-09-2005, 09:58 AM   #1
boraxman
Keepin an eye out
boraxman's Avatar
Removing rivets...
Ive been working on removing the upper rear shock mounts on my truck. I ground the heads off the rivets, beat the mounts off w/ a BFH, but for the life of me I cant remove whats left of the rivets...any tips?
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-09-2005, 10:54 AM   #2
NPilot1975
NPilot1975's Avatar
Drill out the center and then use a punch. You may need to drill it out almost the size of the rivet, if it is stubborn.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 03-09-2005, 11:06 AM   #3
boraxman
Keepin an eye out
boraxman's Avatar
I thought about that, but 2 are hard to get to(above exhaust pipe).
Wasnt suppose to be this hard
ZIP 91351
Old 03-09-2005, 11:14 AM   #4
JimKshortstep4x4
Smile
I center punch the rivets, drill the rivet with a 5/16" drill just to the frame. I then use an air chisel to cut the head off, (cuts very easily). I use a blunt punch in the air chisel to drive out the rest of the rivet.
Jim
Old 03-09-2005, 11:23 AM   #5
COBALT
COBALT's Avatar
Since I don't have air tools I use an angle grinder to grind the head off flush with the frame. You end up with a nice silvery dime-sized area where you can see the outline of what's left of the rivet. A few knocks with a flat ended punch and it comes right out.
Warning: if you suspect there is shear force applied to the rivet due to weight of the vehicle, suspension (springs or leafs) or some other force that has it locked in place banging on it could result in the two members that are being held in place to shift and the holes won't line up any more. Just something to think about.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 03-09-2005, 12:12 PM   #6
junkyardjohn
junkyardjohn's Avatar
Jim
EXACT SAME METHOD THAT I USE. WORKS LIKE A CHARM. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-09-2005, 12:13 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
You will probably have to take off the exhaust pipes. Then use a punch and drive out the rivets. Heat will help. When the rivets were installed they were squeezed, which forced the shank to fill and expand around the hole. It takes some work to get them out.
Easiest way to get them out is if you're really good with a cutting torch and can blow the center out of the rivet without damaging the hole.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-09-2005, 02:27 PM   #8
JimKshortstep4x4
Talking
Fred,
You must be good with a torch!
Jim
Old 03-09-2005, 03:07 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
When I did the upper shock mounts on my truck, I ground the head off them used a hammer to hit the shock mount sideways. That knocked it right off the remaining rivet stubs.
Old 03-09-2005, 03:56 PM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
I use a sharp chisel and a high quality air hammer to cut the rivet off flush with the frame then switch to a blunt point chisel to drive the rivet out. Very quick and loud...
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
