Old 03-09-2005, 12:25 PM   #1
hot!rod
hot!rod's Avatar
Upper and Lower Shafts
I am about to do the 4/6 drop. I will be changing the bearings, seals, ball joints, upper bushings, etc. BUT should I change the upper and lower shafts? I've never changed them and not real sure why I should but I'm sure someone else knows. They don't look like they will be much fun. I get pretty decent prices at the local parts store, but not gonna change it unless it's needed. Anybody know anything ahead of time that they need to tell/warn me? I know the typical ball joint routine. I kinda dread the bushings though. I've never had a set of those go smoothly. Oh yeah, I will be changing the idler arm, pitman arm, rod ends, etc. as well.
Any input?
Thanx,
Brad
Why do we drive on a parkway and park on a driveway?
hot!rod is offline   Reply With Quote
Old 03-09-2005, 04:32 PM   #2
Frank_Zeller
Frank_Zeller's Avatar
Not hard to install......buy the sockets to fit the caps. I bet there worn. To check... Assemble with no coil spring. Then move the arms up and down while pushing front to back. Dont grease them. The grease can mask some of the slop. The TRW shafts are 30 to 35 dollars each at advance auto parts. Think someone did a write up in the FAQ section.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 03-13-2005, 04:33 PM   #3
hot!rod
hot!rod's Avatar
Okay getting ready to reassemble the left side. I read where I shouldn't torque the shaft bushings until it's been aligned. Is that for the lowers, too? It just looks to me like when you torque the bushings, that will put the shaft's threads in a bind and keep them from traveling. I can't figure out what does the moving during suspension travel. Is it the threads on the cross shaft? Can someone please clear the fog on this one?
Thanks,
Brad
Old 03-14-2005, 10:43 AM   #4
hot!rod
hot!rod's Avatar
Anyone?
TTT
Old 03-14-2005, 11:07 AM   #5
Frank_Zeller
See the post in the FAQ section. Lots of other good info there too http://67-72chevytrucks.com/vboard/s...d.php3?t=20551
Austin-Texas
