Old 03-09-2005, 12:49 PM   #1
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Carb gaskets
First question is can an airhorn gasket be reused, or is it better to put on a new one? Second, when replacing the carb to manifold gasket will it be necessary to reset the float if the carb is moved around or turned side to side? I may not be taking the air horn off unless I have to that's why I ask.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 03-09-2005, 03:13 PM   #2
60-66 Nut
Professional Beer Tester
You can reuse the air horn gasket as long as it doesn't tear, but they're not real expensive anyway. The float level should be OK if you don't bend the float. If you change the mounting gasket, just try not to turn the carb upside down unless you're going to remove the air horn and clean the bowl out. Sometimes the sediment in the bowl can cause problems if it moves when the carb if turned over. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 03-10-2005, 12:14 AM   #3
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Thanks, I'll keep all that in mind. I was checking for leaks and seem to have one near the L/F corner of the carb where it meets the manifold. My leak testing method was spraying starting fluid around the base of the carb.
Brad
79 Scottsdale C20
350/350
3.73's
