Old 03-09-2005, 01:55 PM   #1
69ShortStep
69ShortStep's Avatar
WTB:Rear Brake Hose retainer?
I recently swapped out a 69 rear axle for a 72 rear axle. The new 72 brake hose I purchased appears to connect to the axle differently. It looks like a bolt or peg may accomplish this? It could be that I have swapped in a axle set up for leaf springs and my truck is a coil rearend.
If you have what I need or know where I can get it I would appreciate the help.
Maybe if someone could point me to a picture that would be helpful too.
Thanks in advance!!!
69ShortStep is offline   Reply With Quote
Old 03-10-2005, 10:19 AM   #2
69ShortStep
Could someone please supply me with a picture of their 71/72 rear axle that uses coils where the rubber hose meets with the metal brake lines?
Thanks.
Old 03-10-2005, 08:08 PM   #3
JimKshortstep4x4
Smile
There is an angle welded to the front of the axle tube and the brass connector bolts to the angle. The brass connector has the holes in it for the two metal lines.
Hopefully the picture will help. It is a little awkward snapping the pic with the axle in the truck. (The truck is a 71 2wd with coils).
Jim
Old 03-10-2005, 08:54 PM   #4
billsbowtie
billsbowtie's Avatar
i may have what you need i will get a pic. tomarrow
billsbowtie is offline   Reply With Quote
Old 03-11-2005, 12:06 PM   #5
69ShortStep
Thanks for the picture JimKshortstep4X4. It really helps me realize what I need to do.
If anyone else has this angle part, please let me know what you want including shipping to 43112.
Old 03-11-2005, 08:33 PM   #6
billsbowtie
is there anything here you can use
Old 03-11-2005, 08:33 PM   #7
billsbowtie
Old 03-14-2005, 12:17 AM   #8
69ShortStep
Thanks for the pictures billsbowtie.
The pictures from JimKshortstep4X4 seem to match my setup better.
Does anyone have this part or should I make my own?
Old 03-14-2005, 10:37 AM   #9
JimKshortstep4x4
Talking
69ShortStep,
If you measurements of the bracket, let me know and I will measure it for you. It should be an easy part to make.
Jim
Old 03-14-2005, 01:01 PM   #10
69ShortStep
Thank you, I would appreicate those measurements when you get a chance to get them.
Old 03-14-2005, 01:08 PM   #11
JimKshortstep4x4
Smile
I will get the measurements later today and post them.
Jim
Old 03-14-2005, 09:44 PM   #12
JimKshortstep4x4
69ShortStep,
Please send me a Pm, I have a question on the measurements.
Jim
