Union Electrician
WTB taller tv bracket for holley carb on 350/350 th
Hi I need the bracket that holds the tv cable to the motor.I installed a new holly 600 and had an edelbrock on there and the placement of the kickdown attachment on the carb arre diiferent. I ned a taller bracket to get the tv cable in line with where it needs to go on the carb. Thanks Randy
its all about the +6 inches
TTT for you....small detail, but it could confuse some one wanting to help you...you are looking for a kick down cable bracket if it is for a TH350. A TV cable is for overdrive trannys, the function is different...even thoguht the end result is the same.
cut it in half take a scrap piece of metal to make it longer,higher or wider and weld it up in the proper position
