Old 04-10-2002, 07:08 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Question Removing C/10 fender emblems
Hey guys,
What is the easiest way to remove these emblems?. Can I just remove a few bolts on the wheel liner and get a ratchet in there?. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-10-2002, 07:18 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
if your paint is already crappy, the easiest way is to unbolt the bottom of the fender and lighly pull the fender out, just enough to ge a helpers hent in there.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-10-2002, 07:47 AM   #3
Nichboy
Post
Hey 70c10, i put a rag around a screw driver and stuck it between the fender and emblem and mine popped right off. I had to get new clips when i reinstalled them.
1971 Chevy SWB
Oklahoma City, Oklahoma
Nichboy is offline   Reply With Quote
Old 04-10-2002, 07:59 AM   #4
Maximum Overdrive
December 21, 2012
Post
I think most if not all these emblems were bolted on. To pop them off you would have had to have someone taken them off before and put clips on them. Once you have unbolted them go to NAPA and get the clips that let you just slide them in then you will not have to have the hassle of bolting and unbolting them again.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 04-10-2002, 08:02 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Post
Mine are pretty new aftermarket ones but I want to remove them before I get my truck painted.
Jim
Old 04-10-2002, 08:09 AM   #6
JimKshortstep4x4
Smile
All of the C-10 emblems that I have seen are held on with stamped steel nuts unless someone has replaced them with the barrel clip retainers. If you have the factory nuts holding the emblems on, you will break the emblems before the nuts will let go. We pull the liner back after removeing 4-5 fasteners and reach in with a 1/4" drive ratchet or a 3/8" box/open end wrench. Some trucks seem to have more room than others so I have loosened the bottom fender mount bolt to gain the room needed.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-10-2002, 08:52 AM   #7
BubbaGreen
Post
Just unbolt your inner fenders and remove
them, the inners come out really very easy.
You dont need to remove the tire or jack up
the truck...The drivers side is a bit more
difficult only because of the steering shaft.
Once the inners are removed, you have lots
of room/access to get the emblems on/off with
out any damage to anything. If your body
bolts are rusted, dose them with WD-40 good
the night before and then just before you go
to remove them...It really very simple. Also
just be sure nothing is bolted/strapped to
those *before* you try to pull them out!
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
Old 04-10-2002, 09:05 AM   #8
70c10
67-72 Addict!
70c10's Avatar
Post
remove all the bolts or just a few to get access?
Jim
Old 04-10-2002, 11:22 AM   #9
BubbaGreen
Post
You have to remove all the bolts...on the
inner fender, then you can either just let
the fender drop down or take it entire out
its really quite easy to do, assuming none
of the bolts break. Just remember to remove
bar on the drivers side that supports the
opening where the steering column passes
thru.
Old 04-10-2002, 11:46 AM   #10
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Post
First question. Are you putting them back on or shaving them. If you are putting back on then go to the extra trouble. If you are shaving them, then get a metal paint scraper slide it behind the emblem and give it a smack with a hammer, it will snap the stud right off. Then its just a hook shot away to the trash can. hehe
68chevy, 95step bed, euro taillights, fastbags, fully shaved, phantom grill, 350 with a small huffer, TH350, 12bolt Auburn posi 4:11's......... 95 Chevy Tahoe (PHATHOE) all mouldings and emblems stripped, 4/4 drop, Niche Bellas 18's, billet grill, Euro taillights, clear corners, billet antena & wiper covers, leather interior, Pioneer cd, alpine amp, Rockford 15's.......... 97 CBR 900 RR, everything that is aluminum was polished or powdercoated candy purple, 6 color change Chameleon paint at $300 a pint(ouch), custom one of a kind under seat exaust, hand cut decals, runs 11 flat at 126mph FUUUUUUUUUUUUUUN!!!!!!!! ............ my toys at http://communities.msn.com/NSANE68Tr...s/shoebox.msnw
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 04-10-2002, 03:44 PM   #11
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Thanks for all the info guys!. I just got both off a few minutes ago. Both sides were held on with the front barrel nut only. The drivers side was easy- I was able to reach in with a 3/8 socket and get it off. The passenger side I had to drop wheel liner to get to it. My painter is happy plus it saved me shop time. I'm going with pearl ghost flames with a fine silver metallic dust throughout and blue tips to set them off. The front clip into the doors for $750. I've been waiting for this for a year now. I'll post pics when I get it back!. As always thanks for the help.
Jim
