Old 03-09-2005, 10:06 PM   #1
RicksTrucks
RicksTrucks's Avatar
Problem with quick restarts
I have had a problem with my 69 SWB Fleetside. If I turn it off and then try to start it right back (like if I stop for gas and finish too fast) it won't start. But if I sit for a couple more minutes it starts right up. My mechanic changed out the positive battery cable thinking it was too small and heating up. But that didn't help. I don't have any problems as long as I remember not to try and start it right away. So for quick stops, I have to leave it running. Any ideas?
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 03-09-2005, 10:12 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
sounds like the heat is killin the starter. try a heat shield or heat wrap on the starter or mount a remote starter solenoid on your fender
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 03-09-2005, 10:18 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it won't start...
What's it doin?
Crank w/no fire?
No crank?
Crank slow
farts through the carb?
shoots fire out the carb...or the tail pipes...or BOTH
Need more details.
Also, your engine combo will help too.
Old 03-09-2005, 10:19 PM   #4
RicksTrucks
No crank, like dead battery. But wait a couple minutes and fires right up.
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 03-09-2005, 10:42 PM   #5
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Any click from the starter solenoid when you try? I know you said "like a dead battery" but we still need more. Mine would do this after I cranked on it a bit. Let sit and it would start. Crank too long...nothing...no click or anything. I replaced all the grounds and it got better but never healed completely. Some connection was heating up and going dead. I finally ran an additional hot lead from the starter solenoid to the battery. When it happenened again I would put the lead on the battery and it would start right up. I know it is not the starter or solenoid...it is wiring somewhere. Try this bypass to make sure it is not the dreaded heat soak problem.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-09-2005, 10:42 PM   #6
rusted75 half ton
More trusty Less rusty
rusted75 half ton's Avatar
can you turn your lights,ect. on when it won't crank?if you can sounds like bad starter.
rusted75 half ton is offline   Reply With Quote
Old 03-09-2005, 10:43 PM   #7
screamin_c102
screamin_c102's Avatar
Heat soaked solenoid...get a heat shield.
screamin_c102 is offline   Reply With Quote
Old 03-09-2005, 10:45 PM   #8
RicksTrucks
I am currently in Santa Barbara, but will try those things this weekend. Thanks.
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 03-09-2005, 11:18 PM   #9
jhwkns
Registered Cruiser
jhwkns's Avatar
Check the powerblock on the passenger side inner fender. Make sure everything is clean and tight. New connectors, and a bright shiny powerblock can do wonders for these trucks.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 03-10-2005, 03:02 PM   #10
LT4XTREME
I had a 350 in a 70 that would not start hot. The solenoid would click but no crank let it sit a few minutes and it would start fine. The bushing in the starter was bad and the heat would cause it to lock up. When it cooled off it would spin free. I installed a new bushing (cheap if you can find them) and it worked great.
LT4XTREME is offline   Reply With Quote
Old 03-10-2005, 06:59 PM   #11
tom hand
CCRider
tom hand's Avatar
I second that
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 03-10-2005, 11:34 PM   #12
RicksTrucks
Are those standard equipment, something I can find at the yard, or do I need to make one?
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
72 LWB C-10
72 Blazer 4x4 4spd
Old 03-10-2005, 11:39 PM   #13
Gene
Gene's Avatar
Mine acted exactly likke yours, it turned out to be as jhwkns said. The block on the fender had 2 bad connections. I replaced all the wire and ends and havent had that problem since.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 03-10-2005, 11:53 PM   #14
jhow66
jhow66's Avatar
This will take care of it:
http://www.madelectrical.com/catalog/st-1.shtml
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-11-2005, 12:13 AM   #15
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I have oftened wondered with this remote solenoid how the starter bendix gets engaged to the flywheel. Anybody know?
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-11-2005, 02:02 AM   #16
jhow66
jhow66's Avatar
VetteVet
There is a jumper wire from Bat. post on solenoid to "S" post on it. This way when remote is engaged current flows thru bat. cable to starter and "S" post at same time.
Old 03-11-2005, 11:53 AM   #17
raggedjim
raggedjim's Avatar
I had the same problem as LT4EXTREME, if the bushing is worn and the starter heats up the armature will hit the outer housing and lockup. I found this out after I had put in a heat shield, remote solenoid, and everything else I could think of...
Sometimes the simplest things kick your butt...
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 03-11-2005, 07:49 PM   #18
VetteVet
Msgt USAF Ret
VetteVet's Avatar
remote solenoid
thanks Jhow. I couldn't figure out how the bendix was pulled to the flywheel except by the starter solenoid. So instead of the "S" wire feeding voltage to the solenoid from the key switch, it is fed directly from the pos battery cable on the starter as in jumping with a screwdriver for full battery voltage. It must be just enough of a voltage boost to overcome heat soak or will it?Seems like a heat shield is still a good idea especially with headers.
VetteVet
VetteVet
Old 03-11-2005, 08:51 PM   #19
widow_maker
This space for lease
widow_maker's Avatar
My 69 was leaving me stranded at times as well. I to added the heat shield between my headers and the starter and protected the connections at the solenoid but continued to have the same problems. I finally drove the truck till it was good and warm then stopped at the parts store for a run on the diagnostics unit. The system said my battery was dead. Once the truck cooled slightly, we started it and did the test again. It said the system wasn't charging at that point and to test the regulator. It failed! My problem wasn't at the starter but rather the regulator under the battery tray. Ultimately, my alternator gave up the fight a short time later as it was being overworked by the faulty regulator. Just another idea.
If everything seems to be going well, you have obviously overlooked something.
1972 K-20 l/f 383/350 a/c "custom camper"
1987 V-20 l/f Silverado - project
widow_maker is offline   Reply With Quote
Old 03-11-2005, 11:08 PM   #20
jhow66
jhow66's Avatar
VetteVet
Here is the problem--When the solenoid on a GM setup gets hot it takes as much as 40 amps to pull the plunger in solenoid. The current flows from battery in to ign. switch then to netural safety switch then to solenoid--hence not enough amps to pull it. With the MAD setup (F**D solenoid) it only takes 4 AMPS to pull it's plunger which then sends full battery voltage to starter & solenoid-problem solved. All the F**D guys in our circle of car nuts kid us about buying up all of their parts to make our CHEVYS run. You are right about sheild as it will help also.
