Old 03-10-2005, 10:01 AM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Question Aftermarket gauge wiring question
I'm starting to install Autometer gauges and have a question about the wiring to the instrument cluster. According to the wiring diagram I have:
* Light Blue wire, 14B is the left turn signal
* Dark blue, 15B is the right turn signal
* Light Green wire, 11B is the high beam indicator
* Brown wire, 25 is the alternator indicator light
* Pink wire, 39 is the ignition switch feed controlled
* Tan wire, 30 is the fuel level
* Blue wire, 31 is the oil pressure
* Gray wire, 8A is the instrument panel lights
* Tan wire, 33B is the brake warning lamp
* Dark green wire, 35B is the water temperature
My question is; where does the pink wire (39) tie into the new gauges since the factory connector and printed circuit are gone? Thanks
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 03-10-2005, 10:08 AM   #2
Putter
More Cowbell....
Putter's Avatar
I am anxoius to see that answer myself. I have new Autometer gauges also, but haven't gotten around to installing them yet.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 03-10-2005, 11:08 AM   #3
Portmod7
Portmod7's Avatar
I have done it, but it was a while ago, I don't remeber exactly. What does the pink wire do? I understand "oil pressure", "water temp", but not "ignition switch feed controlled". If you could explain that for me I might be able to help.
Have Fun! Got a lot of compliments on mine when I got done.
Portmod7 is offline   Reply With Quote
Old 03-10-2005, 11:42 AM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
Putter, This morning I spoke with one of the guys I work with who was a GM mechanic for years and his answer was that the Pink wire is the switched circuit to turn the electric gauges on when the ignition key is turned on so they can start receiving their inputs from the various sensors they are connnected to. So, the Pink wire will tie to the positive side of each electric gauge. Finally, it makes sense to me...
Just Passin' Thru
Old 03-10-2005, 12:11 PM   #5
Putter
More Cowbell....
Putter's Avatar
Cha-ching. And now...you know....the..resssst.....of..the....story. Good day!
