Old 03-10-2005, 12:34 PM   #1
greenvilledave
will it fit
real quick question before I buy this thing does anyone know if a 11" flywheel will fit in a three speed bell housing. Do you know of any other problems going to match up a re-built 350 to the three speed with a hurst floor shifter and I think a 10" clutch system will get ribbed apart. dave
greenvilledave is offline   Reply With Quote
Old 03-10-2005, 12:58 PM   #2
JJR
JJR's Avatar
To my knowledge (and looking at Hollander), there was only one manual transmission bellhousing used on 68-72 Trucks no matter what engine/trans was installed. The 67 model used the same bellhousing as the 65-66 truck. Also, a 10" clutch only came on 6cyl trucks (the 6cyl HD clutch was 11"). All V-8's got a minimum of an 11" and some got HD 12" clutches. Hope this helps.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 03-10-2005, 03:46 PM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I think the diameter of the flywheels are the same except for the 10 inch,which is different,and requires a different starter.The 10" uses the 1 long1 short bolt starter,and the rest use the 2 long bolt starters,unless you have the cast bell for a 4 speed,then the starter bolts to the bellhousing.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-11-2005, 03:53 PM   #4
greenvilledave
thanks for the info, so if i change to a 11" flywheel and clutch I will have to change starters also and does anyone have a 350 with a 10" clutch system and do you have any problems Thanks again Dave
Old 03-11-2005, 06:46 PM   #5
Brainchild
Brainchild's Avatar
If your gonna do any hauling,or pulling at all I would go for the 11" clutch.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
