![]() Join Date: Sep 2004
Water temp gage question
I plan to install my Camero tach soon in my bezel. While I have it apart,
I'm wanting to install a water temperature gage in the blank vacuum gage spot. What gage will work best for this? Anyone done this? Instructions? Pictures? Suggestions? Thanks, Aitch
69 GMC 3/4 ton LWB 383 TH400 Dana 60 '84 300ZX '79 Nova (for sale) |
ttt
graphic designer
so you're gonna have 2 water temp gauges? there should already be one on the left side.
#4 | |
I admit there is a lot I don't know but I don't think my temp gage on
the left actually shows what temperature I'm running. Mine registers C - H. What does the factory gage actually sense, is it water temp? Again, I don't know where the sensor is placed. If the C - H gage is a good indicator of engine temperature then I don't need anything else. Thanks aitch Quote:
Questionable
I think someone makes an analog clock that will fit in the hole. I know I've seen it somewhere, but I can't remember where
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#6 | |
graphic designer
Thanks all, the mechanic that did the install on my fresh 383 said that if it was his, he'd get a water temp gage. I'll ask him about it this weekend.
