Old 03-10-2005, 01:55 PM   #1
RED71CHEVY
RED71CHEVY's Avatar
pinion angle for lowered trucks
how knows the correct pinion angle you need to have ,when you lower the rear by4" and the front by 2.5".
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 03-10-2005, 02:37 PM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
http://www.2quicknovas.com/happypinions.html
Here's everthing you ever wanted to know about pinion angels
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 03-11-2005, 03:39 AM   #3
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
are those the angels sent by the differential gods?
CHEVIBUBBA is offline   Reply With Quote
Old 03-11-2005, 09:31 AM   #4
jamis
F.A.S.T. president
jamis's Avatar
The pinon angle has to be the same as your trans output shaft angle for a comfortable trouble free street aplication. If you have trailering arms and used shorter 4" springs to lower then a 1 or 2 deg. wedge should be enough to compansate if you have done no other mods to the trans crossmember. The best way to know for shure is to measure the angles with a degree finder.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 03-13-2005, 09:53 AM   #5
RED71CHEVY
RED71CHEVY's Avatar
thanks for the info, the angels have been watching over this topic and tell me to read the article @ the '2quicknovas' site.
TIM
