03-10-2005, 04:55 PM | #1 |
Keep On Truckin'
Driver side firewall picture needed
Well, I'm puttin' the truck back together and I've slept several hundred times since I took it apart. To make things worse the pictures I took when I disassmebled it have vanished. I was wondering some of you could post pictures of the firewall (engine compartment side) showing the holes, brackets and wiring coming thru the firewall. Also, a few shots of the underside of the dash on the driver's side would be real helpful too. Thanks
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
03-10-2005, 05:10 PM | #2 |
Dont know if this will help much.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille Last edited by pat; 03-10-2005 at 05:18 PM. |
03-10-2005, 05:11 PM | #3 | |
Keep On Truckin'
Yes, that does help! Thanks
03-10-2005, 05:12 PM | #4 |
I do not know how far you are from Garland "north of Dallas” but I have a 72 with no front end or motor and nothing in the dash with everything still running through the firewall if you want to come by and look at it. I will try to get you Photos Tonight.
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi |
03-10-2005, 06:48 PM | #5 | |
Keep On Truckin'
Garland's a tad far, I live just south of Austin. Pictures will be greatly appreciated. Thanks,
03-10-2005, 07:04 PM | #6 |
Questionable
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-11-2005, 12:30 AM | #7 |
pic
out side firewall
03-11-2005, 12:31 AM | #8 |
pict
outside center
03-11-2005, 12:32 AM | #9 |
pict
inside by fuse panel
03-11-2005, 12:33 AM | #10 |
pict
inside center
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi Last edited by flip66; 03-11-2005 at 12:35 AM. |
03-11-2005, 12:43 AM | #11 |
huh ???
This might help too...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
03-11-2005, 12:06 PM | #12 |
Questionable
I have the truck at work today. I can go out and snap some close-up shots if you want. Just lemme know.
03-12-2005, 03:05 AM | #13 |
Keep On Truckin'
Thanks guys!! The pictures told me waht I needed to know..
