Old 03-11-2005, 01:02 AM   #1
bumpster
Junior Member
You need one of these
I know a lot of you need high amp alternators for winches, stereos, and such, so upgrading to an internal alt is the way to go. On my 72, all I needed was for the lights to stop going bright, then dim, then somewhere in between. I installed an electronic voltage reg from whitney, (item AJQ737135R), simply because it was cheap(10 bucks), and I didn't have any more late style alts. laying around. This thing works good, looks and installs just like the factory setup, and made a huge difference. Now alt kicks in at about 400rpm and no more power surges. If you want to keep showroom looks this would be a good route.
72 C10 10 yr.daily driver
68 C10 18 yr.money pit
72 Nova all original
99 H.D. Heritage[sanity check]
71 VW topless bug[summer fun]
"When I have the money, I don't have the time ; when I have the time, I don't have the money.
bumpster is offline   Reply With Quote
Old 03-11-2005, 01:50 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
regulator
I can see why a solid state regulator would solve your voltage surge problems but how is it going to increase the output of the alternator. Are you talking about using it in the old style external regulated alternator right? I didn't know they would work, but then I never tried. You are talking about this aren't you.
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-12-2005, 08:48 PM   #3
bumpster
Junior Member
VetteVet
The new regulator mounts to the core support and looks just like the old relay style reg, using the same plug-in. The (old style) alt. is not changed in any way.
