Old 03-11-2005, 02:37 AM   #1
Gyva
Gyva's Avatar
Fuel guage problems
My fuel guage does not move anymore. It has found its resting place past the full mark, it hangs out at about the 2 or 3 o'clock position and just sits there. I know I need a new fuel sending unit in my gas tank but why did my needle go completly out of the e to f range? thanks for any help, and where do you recomend I get an aftermarket fuel sending unit
Mike...
Gyva is offline   Reply With Quote
Old 03-11-2005, 02:41 AM   #2
Alexis
Member since 2000
Alexis's Avatar
check your connection on the fuse box..........it should be a brown wire if memory serves me right, it is just a female connector that conects to the fuse box......it comes out sometimes. If it isn't that then well move onto the next thing, sending unit or the wiring to the gauge.
goodluck, i know other will give other ideas.
Alexis is offline   Reply With Quote
Old 03-11-2005, 04:05 AM   #3
HatGuy
HatGuy's Avatar
While we are on the subject. My gauge works
but wiggles back and forth about a half inch
even when it is sitting still. Do I need a new
sending unit ?
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 03-11-2005, 06:21 AM   #4
HillBilly2357
HillBilly2357's Avatar
I've got gremlins in my fuel gauge too (in my 3/4 ton). But mine jumps from normal to way past full (about 3 or 4 o'clock), stays there for a few seconds, then falls back to normal. It does this continuously.
72 GMC Jimmy
72 GMC 3/4 ton Camper Special
70 Chevy 3/4 ton (in pieces) FOR SALE!
HillBilly2357 is offline   Reply With Quote
Old 03-11-2005, 11:49 AM   #5
ssls6
If your gauge goes way past full, then you probably have an open circuit between the sending unit and the gauge. Check that the brown wire from the tank is connected (both at the tank and at the fuse box). If the brown wire is OK (test at the fuse box with a multimeter 90 ohms is full, 0 ohms is empty) then the open could be in the printed circuit harness.
typical fault tree
needle way past full.....
open circuit between sending unit and dash
sending unit is bad
needle stays on empty...
short between sending unit and dash
leak in sending unit float
needle works but only between 1/4 and empty
82 ohm ballast resistor behind gauge is bad
needle bounces around
bad gauge
Use a multimeter when in doubt.
ssls6 is offline   Reply With Quote
Old 03-11-2005, 01:13 PM   #6
71jimmy
71jimmy's Avatar
Nice troubleshooting steps ssls6. Any idea if you can fix the bad guage that bounces? What part in the guage would cause it to bounce?
I just replaced my tank, sending unit etc and filled up for the first time and I got the bouncy gauge syndrome.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 03-12-2005, 02:10 AM   #7
HatGuy
HatGuy's Avatar
Thanks ssls6,
The trouble shooting guide is great!
Looks like I'll be shoping for a new gauge.
72' K5 Highlander
My Daily Driver
Old 03-12-2005, 08:00 AM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
HMMMM, BRAND NEW SENDING UNIT HERE, READS EMPTY, SOUNDS
LIKE THE FLOAT ON MINE MAY HAVE SANK / GOT A LEAK IN IT.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-12-2005, 05:19 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice trouble shootin guide hope fully it will help me on mine bad guage...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-13-2005, 07:44 PM   #10
Gyva
Gyva's Avatar
Luv2xclr8: or maybe you got a short according to the trouble shooting guide above...
Mike
Old 03-13-2005, 07:46 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Mike
WE CHECKED IT, MIGHT HAVE MISSED IT, BUT IT LOOKS AS IF IT'S THE FLOAT
