03-11-2005, 04:18 PM | #1 |
Certified Truck Nut
'82 GMC backyard tub job ?s
i think the longbed is about due for some slightly more massive tire...so here is my idea...
i wanna box my rails and move the existing leafs inboard, switching the hangers and shackles so i could still use the stock pieces. has anyone ever tried this? i wanna do this and relocate my shocks so that i can run tire from bodyline to framerail. that outta let me run some MASSIVE rubber if im looking at it right. also, if i do this and do a flip at the same time will i have to C notch? thanks for any input later Dan
1982 GMC Sierra Classic 1500 Longbed 350, TH350, 3.73 10 bolt soon to be slammed |
03-11-2005, 08:16 PM | #2 |
Head Peon
I talked to a guy with an S-10 and he actually swapped the framerails side to side to get the stuff in the middle...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
03-11-2005, 08:16 PM | #3 |
Yes, it's possible (and old school pro-street on the cheap). Box the inside frame rails. Switch the hangers to the inside of the frame (drivers to pass inside, pass to drivers inside). Re-mount the pads that locate the housing & then the shocks so they clear everything. Do the flip kit & c-section, then cut the bed floor & add a section of steel to widen the tubs (part of another wheel tub works well cause it's already the same shape) or use aftermarket tubs for clearance.
03-14-2005, 03:34 PM | #4 |
Certified Truck Nut
anyone ever tried it? just curious
