Old 03-11-2005, 04:47 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Question How do I remove...........
How do I remove the BOLT that holds the Panhard Bar to the differential? Is it pressed in and does it have to be pressed out? I have removed the nut holding the bolt in, but it won't move.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 03-11-2005, 04:48 PM   #2
Alexis
Member since 2000
Alexis's Avatar
i thought it was bolted in? on the front side of the diff.
edit:
i think it might be like a huge bolt you, so you might need vise grips to turn out......been to long since i took it out.
Alexis is offline   Reply With Quote
Old 03-11-2005, 05:05 PM   #3
cdowns
cdowns's Avatar
when trying to remove the panhard bar the rear must not have weight on it because this will load the panhard
Old 03-11-2005, 06:37 PM   #4
jugernot
Life, Be In It.....
jugernot's Avatar
I have removed everything off of the rear end, so I can have it blasted. I have removed the nut on differential panhard bolt, but it looks like it is pressed in. I even tried hitting it with a BFHm, but it did not seem to move. Anyone have any thoughts/ ideas?
Old 03-11-2005, 08:23 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Twist it with a pipe wrench and it will pop right out. It's a taper fit.
